(1) 2 3 4 5 »
how do i get my a15 performing again
need to give this thing a kick in the pants now....
plan of attack once it comes back from being derooed is:
fresh plugs and tune. Currently running e15 elec dizzy so will put 0.8 gap on the plugs and advance the timing to around 14 or a bit more if it will take it... currently set at 10 deg.
will also do fuel filter agin and see how that goes.
if still not much better, will have to save up and invest in some carby specialist and dyno time.
47.4kw atw was a joke to me, ithought 80hp atw so if i can get to there, its good, more is better.
Any other thoughts form people (no forced induction, maybe 32/36 might be a better option that the sus' but like them too much)
Posted on: 2007/5/28 10:15
Re: how do i get my a15 performing again
stick with kW or HP ... confusing me with mixing them ??
by the way - whats the conversion from kW to HP ??
Posted on: 2007/5/28 10:22
From penrith,sydney,aus
80 hp is 59.656 kw as per my nokia mobile converter
Posted on: 2007/5/28 10:25
2 door 1200 sedan project l20b stroker
Posted on: 2007/5/28 10:26
From Geelong, Vic
1hp = .7456999kw
1kw = 1.341022 hp
so mik i think you need some dellortos
Posted on: 2007/5/28 10:29
was actually thinking should come down and have a play in your shed and see if we can get it running better. between you and your miricle brother, the saviour of our datto cruises.
Posted on: 2007/5/28 10:32
From sydney
I would take the SUs over the weber for performance.
Posted on: 2007/5/28 10:38
so i'm looking at around 78.18hp ATW .... if i use your 15% driveline loss i could be looking at around 92hp at the flywheel .... better get cracking mik
get it straightened and bring it down here for a tune - pretty cheap and the guys definitely know what they're doing
Posted on: 2007/5/28 10:39
From Melbourne Vic
ccc...
cam, compression, carbs
Posted on: 2007/5/28 10:40
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Melbourne Vic
i thought drivetrain loss was 30%...
Posted on: 2007/5/28 10:41
(1) 2 3 4 5 »
