IRS in ute?
has any done a coversion to put inderpendant rear susp into a 1200 ute? like from a 1600 or something? it would obviosly handle better, yeah?
Thanks again ben.
Posted on: 2007/6/21 11:53
Re: IRS in ute?
From Melbourne, Australia
why would it handle better?
Posted on: 2007/6/21 11:55
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: IRS in ute?
From Adelaide, Australia
Look under pigdogs pictures.
Edit for rallycar: adjustable toe and camber is easily achieved with IRS, but really not worth the effort in my opinion.
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: IRS in ute?
might be in for some more pics from pigdog as i believe a litle more works been/being done.
theres also some other pis floating around of another ute that was running IRS and a daily driver from memory ??
Posted on: 2007/6/21 12:03
Re: IRS in ute?
PIGDOG, if you look at this swap your halfshafts end to end and you will get less wear and a better angle (you'll break them like that in 2seconds), did this in my 1600 when lowered it.
Posted on: 2007/6/21 12:07
IPRA Build
Re: IRS in ute?
From Geelong, Vic
its not that low any more...angles alot less
chassis is complete now, so now on to trans tunnel and tailshaft tunnel
Posted on: 2007/6/21 14:12
Re: IRS in ute?
From NSW, Australia
I would love IRS in my ute, Not just the handling aroung corners, but how nice does the camber look when its sitting on the ground
Alot of trouble, but very nice mod.
heaps interested pigdog in seening the end result of your project.
Posted on: 2007/6/22 1:45
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: IRS in ute?
From Brisbane, Australia
I'm not such a big fan of IRS from a performance point of veiw. particularly the Datsun semi trailing IRS setup like in the above pics:
1) its heavy
2) poor geometry control - ie toe, camber, and roll centre though suspension travel all changes alot, which means all sorts of nasty things happening during cornering - bump steer, weight jacking etc.
3) excessive squat geometry too
the 'fix' adopted by most circuit cars is 1200lb springs to eliminate as much movement as possible. I think the wheel rate of that is a smidge over 300lbs
much easier and better to simply set up a good leaf spring live axle under the back of the 1200. It will work beter and be lighter.
oh, and all those extra unis soak up some power too.
but if you are after comfort or the camber look (which is not actually what you want for the rear for good performance/handling)
Posted on: 2007/6/22 3:05
Re: IRS in ute?
BigD wrote: how nice does the camber look when its sitting on the ground
Rear camber doesn't do it for me. It's a combination of the ridiculous tyre wear and lack of traction but, each to his own.
Posted on: 2007/6/22 3:17
Re: IRS in ute?
From NSW, Australia
some really nice info there L18_B110.
I personally preffer IRS (not being a circuit racing guy) i love my Rally and street crusing. What i know is some of the best Datsun rally cars 1600, 180B SSS etc all have IRS standard. These days all sorts of manufactures release cars for luxuary and performance like Holden with IRS standard. Took them 30yrs to figure it out.
Not saying its better in all applications But as you can see i am a fan, and it looks tuff too.
Posted on: 2007/6/22 3:29
Cheers,
Big D
