1200/120Y brakeline nut sizes?
From Quairading, Western Australia
like the topic header says...
what is the size of 1200/120Y brakeline nuts?
going up to the farm on thursday - hope to have TD3 running by next wednesday!
Posted on: 2007/7/17 9:41
Re: 1200/120Y brakeline nut sizes?
From Canberra
10mm, or if you round them off (I usually do ) then file 2 sides down a fraction so its a tight fit with a 3/8". Or just take locking pliers
Posted on: 2007/7/17 10:38
From Melbourne AUS
if your careful and gently apply pressure the nut will most likey round before its undone.
the trick is to "crack" them open with a good shock.
works for me
Posted on: 2007/7/17 10:43
1973 B110 A12
From Geelong, Vic
of just get some rostoff, spray a heap of that on then wait a bit
also might help to do them up slightly, sometimes helps to loosen them if that makes sense
but yeah 10mm pipeline spanner or vice grips
Posted on: 2007/7/17 11:22
I just bought a 3/8 brakeline spanner today - strangely enough
Posted on: 2007/7/17 11:56
From Burbank, CA
it's m10x1.0
I use locking pliers... those nuts are !!!@#!@!@@@ to get off...
Posted on: 2007/7/18 2:23
|||\ 81 KPB310 /|||
