Removing bumpers & Steering wheel
From Sunny Coast, QLD
I'm planning to paint my 74 120Y in a couple of weeks and I had a look at the bumpers and couldn't see how they come off. Is there an easy way to get them off or would I better off just masking them and spraying with them on?
And how do you take off the original 120Y steering wheel?
I tried pulling the plastic stuff off the centre but it felt like that would wreck it & the side bits dont seem to come off.
Posted on: 2007/9/5 20:15
Re: Removing bumpers & Steering wheel
From Tamworth , NSW
are there some screws on the back of the wheel that hold the center peice of pastic on??
Posted on: 2007/9/5 20:58
From Coondle, WA Australia
the 1k centre horn piece is just held on with twist tabs. You pus the horn in and twist to the left and it comes off.
If there are no screws in the back of the horn cover you could try that.
Posted on: 2007/9/5 21:06
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Tamworth, NSW
Once you get the plastic off there will be a centre nut.
To get the steering wheel off the shaft you need a gear puller but you can try yanking it off the only prob is that it may get implanted in your face
Posted on: 2007/9/5 22:13
Project coupe:
Just drive it
Thanks. I'll check out the wheel in a minute. I should be getting a boss kit in the mail soon so I can finally put on my new wheel.
Anyone got any ideas about the bumpers?
Posted on: 2007/9/5 22:58
From Sydney Australia
To take the steering wheel off, undo that centre nut, but dont take it off, leave it on by a couple of turns. Then just pull on the steering wheel. It will move up to the nut with a bit of heaving, then you just take them both off easily and save your nose.
Posted on: 2007/9/6 0:10
From Tasmania
Ianey you you jsut wrote exactly waht I was going to.
Posted on: 2007/9/6 0:12
Proud member of " The Tasmanian Datsun Owners Group"
From Canberra
the bumper will have 2 big bolts on each side holding the bracket to the chassis rail, you can undo them or undo the bolts that hold the bracket to the bar (probably rusted and will snap). There are also bolts on the sides holding the bar to the guards.
The steering wheel will have screws from the back holding the rubber pad on. Then do what Ianey said, just dont use a hammer.
You could make a steering wheel puller ut of a bit of 3mm plate with 2 holes drilled in it if you needed to.
Posted on: 2007/9/6 1:12
From Quairading, Western Australia
the rear bumper is held on with 2 14 or 15 mm bolts
Posted on: 2007/9/6 2:38
I'll have to check it out when it stops raining (probly not for a few days ).
So would you say it'd be better to just mask the bumpers instead of breaking a bracket?
Posted on: 2007/9/6 7:34
