Being cooking my brain for a while on reading about 6 stroke, split cycle and other fuel/steam hybrids and come up with this.
Since the A series and L series are non crossflow it would be relatively easier to mod one to run in the 2 following setups....
1. the Split cycle like scuderi engine but different here could be applied with the use of a custom camshaft, timing, manifold tubes connecting 1 to 3 and 2 to 4(or 1 to 2 and 3 to 4 havent worked that out yet), Big steel sleeved bores on 1 and 3 (or 2 and 4) and offset ground crankshaft to make the crankpin at TDC to be 2-6 degrees on the downstroke. Not forgetting full balancing on both concepts.
By using the bigger volume cylinders to pump the air into the smaller cylinder (eg cyl 1 drawing air on the inlet stroke and then exhausting it to the next cyl either 2 or 3 (depending on crankshaft firing order I havent worked that out I need a simulator) an injector placed on the tube connecting the cylinders injects the fuel in the airstream as it enters the second cylinder.
The secret is to make the fuel combustion cylinder fire following the quick opening and closing of the inlet valve releasing the pressurised fuel and air mixture just after TDC. This will allow the exhaust gases to exit completely almost better than a conventional 2 stroke engine does. The combustion occuring just after TDC is able to maximise the downstroke increasing torque.
Can it work on the A series or L this way?
Also if it was applied to a 6 cylinder engine the 3 cylinder could be pushed with a mixture of exhaust gas and water squirted into the connecting tube which will expand (water expands up to 1600% to push the piston with awesome torque and exhaust the gas and water mix into a turbo.
2. The second version is just using the first power cylinder as a 4 stroke to to push the exhaust and water mix into the second cylinder (working as a normal 2 stroke that is valve opens and closes at just before and after TDC) to expand this second cylinder without burning fuel and a pneumatic air valve in between the feeding tube (from cyl 1) to let external fresh air in, along with the same amount of water to cool the second cylinder further and perhaps help keep the engine cooler overall. This engine would use water as a fuel with the help of the exhaust heat so would need two tanks one for fuel and one for H2O. Can anyone help with any problems associated with this application also?.
Heres the animation that kept me awake at night (of course this is using an almost simultaneous firing pair of cylinders) My concept wouldnt need to. Also in concept no 1. the first cyl combustion chamber could be welded where the intake valve is and opened where the exhaust valve is to help air flow into a pocket like chamber so aid the exhaust as this cyl wont be needing to combust but just feed the second cylinder)
http://www.scuderigroup.com/technology/animations/split_sideview.html
