help with installing an a14 into a 1000 engine bay
From Melbourne Vic
Is it the same as an a12 install but for the extra height?
i'm going to be starting tomorrow its currently an a10. so i trim the gearbox input shaft 10ish mm and have to make some engine mounts.
anything else?
wiring of the new position of the dizzy?
Posted on: 2007/10/11 11:40
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: help with installing an a14 into a 1000 engine bay
From Freo
smash in an A12 gearbox, the clutch will like you..
I think the Dissy wire is long enough...
Posted on: 2007/10/11 11:44
A15 PSI Project Motor
'72 CB750k,
From Melbourne Vic
isn't there heaps of fiddling around with clutch fork actuation tho with the a12 gearbox?
Posted on: 2007/10/11 12:08
From Perth WA
Yeh run a 1200 box. You will blow up the old a10 box in no time! To make that fit you need to do some gentle masaging to the tunnel and use a 1200 clutch cable. People say you need the 45deg thing on the firewall for the cable... but i got away without it.
Height wise, you cant run a 1200 frypan, thats about it, and other highish filters will foul!
Posted on: 2007/10/11 12:18
Chris...
From South Africa, Bloemfontein
Ask Dodgeman.
He installed a A12GX motor and a datsun 5 speed gearbox.
Think it was a 60A series gearbox.Can't really remember.
Posted on: 2007/10/11 12:20
1977 Datsun 1200GX
From Coondle, WA Australia
make sure that you fit the engine far enough back otherwise the belhousing will fowl on the steering arms. That almost caught me out...
Posted on: 2007/10/12 2:15
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Freo
yea just a little massage with a ball pein hammer and the 1200 clutch fork will clear,
it makes the clutch nice and light too...
Posted on: 2007/10/12 3:57
'72 CB750k,
From Perth Western Australia
I've got two thou's with A14's - here's a list of woes I've come accross.
Gearbox - it's the biggest one as beattie has mentioned the tunnel up near the firewall needs some gentle massaging to allow the 1200 clutch cable to oppereate freely.
You can get away with a A10 box but i found even moderate driving caused slipage in the clutch after a while it's just so small!. Using a 1200 box negates the need to machine imput shaft as well!
The air filter will foul, I cut down the lip of the oringinal pan on one and used a thinner filter and it cleared - just! or as mentioned go aftermarket - or go sidedraft........you know you want to!
No bonnet clearance issues here!!
Engine mounts - the thou has funny angled mounts which are bloody hard to replace - if you can modify the bracket from the engine to accept 1200 mounts your winning before you know it!
I used a A12 dizzy on the A14 all wiring was the same as far as I can remeber.
Good luck!
Posted on: 2007/10/12 6:09
Datsun 1000 it's
All-round Action!
Thou Coupe worked A14 twin bbq's
From perth airport
hey just while where on the topic does any one know wat cars came wit the a14 rwd standard or even better a15 rwd ... i have been searching and unable to find much :(
this is wat i have found 1980sunny wagon a14 rwd.... 81 same ........ 79 same ...... and the 79 sunny van a14 rwd ..... wat are the a15 IN ???????
i bet the sunny wagons and vans are rare???
Posted on: 2007/10/12 6:38
perth airport parking
Datsun 1200 ute A14
some vannettes had an a15, and the last of the sunnys i believe.
Yeah and Kue, I gotta come over and visit to get a good look at how you have made the engine mounts and gearbox mounts. If you dont mind that is.
And I love sideys. They just do it for me every time, but EFI is just that one better
Posted on: 2007/10/12 7:53
