(1) 2 3 »
Bakkie with L28
Not too shy to talk
From Cape Town
The owner says it runs hard
another,he had to modify the firewall a bit!!
he plans to fit tripple sidedraughts
Posted on: 2007/11/4 4:41
Re: Bakkie with L28
From Perth WA
Thats pretty crazy. Seen a pic of a red 1200 with a L6 in it before... i think in the tech section here.
I recon if he had a thin rad and mounted it really far foward and then moved the engine right up and ran a thermo fan it would fit! Must be a pig handling wise considering the extra weight!
Yeh waste of time running that single carby! 240Z SU's would be a better bet! Or like you said, triples!!!
Posted on: 2007/11/4 4:45
Chris...
Re: Bakkie with L28
From Canberra
does the gearstick come out in the cab or the tray?
Posted on: 2007/11/4 5:51
Re: Bakkie with L28
From Wagga Wagga, NSW
now a little while ago somebody had killed there L18 in there 180B and was asking if an L6 would fit beacuse he was offered one cheap but the blokes talked him out of it saying it wouldnt fit but now seeing this picture makes me think if it fits in a 1200 with a little bit of firewall modification then it would fit in a 180b without any or close to no firewall mods would be woth a try with a turbo and factory 280zx injection that would be fun!
Posted on: 2007/11/4 9:41
Re: Bakkie with L28
From South Africa
that amount of effort, and I would have a 20B in there... well actually a 20B would go in for about half the effort...
Posted on: 2007/11/4 15:49
Re: Bakkie with L28
Here is the L26-powered 1200:
Ron Folck's 1200
Posted on: 2007/11/4 18:32
Re: Bakkie with L28
From SA
Does it still have the stock struts? I also have a 280ZX FI with 5spd box stashed away and did consider fitting it to my 1200GX coupe?
Posted on: 2008/1/18 17:25
Re: Bakkie with L28
From NSW, Australia
Wow what a crazy conversion!! yea the 20B might be half the trouble but more than double the cost.. I think you cant go wrong with keeping a nissan/Datsun motor in a Datto shell. (but i do love my rotors too) With the L26/L28 you can get a EFI manifold that will bolt straight on (Like off the R30 etc) then depending on the power some aftermarket injectors and computer and your kicking ass. i had a 1970 skyline that i fitted a L28, EFI with a T04 turbo (worked/boosted) and i got 311hp on the dyno, so im used to these motors. But in a 1200 the power to weight would be very dangerous. im thinking of going L20 Turbo in my ute for the next rebuild down the track.
good luck !! keep us posted.
Posted on: 2008/1/19 0:29
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: Bakkie with L28
From Wagga Wagga
Dose any1 know what series engine is in my datsun truck?!? it's 3000cc straight six, 120HP at 3200rpm. would be a nice in a datsun 720!.... or something.
Posted on: 2008/1/19 1:08
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
Re: Bakkie with L28
From Coondle, WA Australia
wouldnt be an early RB30 would it??
Posted on: 2008/1/19 10:54
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
(1) 2 3 »
