« 1 2 (3) 4 »
Re: Brake upgrade without track increasing.
From The garage, NZ
Just as a little bit of useful information, cefiro's and im pretty sure laurels use the same 4 stud brake setup as s13's. That includes wheels studs. So they might be a hell of a lot cheaper than s13 setups at wreckers etc.
Posted on: 2008/1/21 21:27
From whakatane, but most of the time canterbury NZ
If you can do the machining yourself then you might want to look at how I have done my setup. I used the drum struts so you end up with bigger stub axles and only 2.5mm track increase either side
Disk upgrade
Posted on: 2008/1/21 21:40
Experience is directly proportional to the amount of equipment ruined.
From Las Vegas USA
An option if it hasn't been mentioned is going to a Wilwood caliper, they make a whole host of sizes that will fit in small wheels and can be used with a solid rotor.
Tom
Posted on: 2008/1/22 3:44
From Burbank, CA
I'm trying to get those added to the brake swap wiki.
they work with the vented rotors too.
Posted on: 2008/1/22 4:01
|||\ 81 KPB310 /|||
From Arlington, TX, USA
B210sleeper wrote:
The 280zx struts require coilovers or changing the spring perches, camber plates.
Actually, it's quite easy to do the swap with none of those things.
When you take the stock struts off, find someone with a plasma cutter to cut off the stock 1200 spring perches. You can then set those inside the 280ZX spring perches and weld them in place. Then you just fit up the 1200 springs, and upper bits. Works a treat and only requires some minor cutting/welding, not extra custom parts.
Posted on: 2008/2/19 4:08
1973 Datsun B110 Coupe (A15/5spd)
1977 Datsun 280Zed (5.0L/5spd)
From Burbank, CA
or you can do that...
I suppose it can be done fairly cheap and be nearly as good.
Camber plates might be nice since there isn't really any adjustment of the camber normally.
Posted on: 2008/2/19 5:22
|||\ 81 KPB310 /|||
From South Africa, Bloemfontein
Here where I live we have found an excellent brake upgrade.Unfortunately it is for newer "bakkie" struts that you guys don't have there on your side.I have noticed that the old 1200 setup the calipers are at the back of the struts.The newer 1400 "bakkie" struts the calipers are at the front.So, with a brake upgrade that will consist of bigger calipers, there is no need to worry anymore about a caliper that might hit the steering arms and stuff.
I still need to see if this setup will fit under 13" rims because I want to do this upgrade to my own GX as it currently has the stock "bakkie" strut/brake setup.
What I must mention is that all you guys are talking about old setups that are already old and difficult to get parts for here in ZA.Example, 280ZX,etc.
The setup that we are using is late 2000 model Nissan Almera (Pulsar in Aus) brake discs.Apparently they fit over the hub without drilling new holes.And then Ford Focus calipers.Also a late 2000 model.
Just need to make a adapter plate to bolt the caliper in the right position.
This setup is currently on a friend's 1400 "bakkie". He was a go-cart driver once and knows how to work brakes HARD.
I once went for a spin with him.
3 times in a row. from 0km/h to 200km/h and back again to 0km/h.
When I got out of the car I immediately looked at the discs to see if they overheated and there was nothing.
Posted on: 2008/2/19 8:43
1977 Datsun 1200GX
From Springwood NSW, Formerly Tas.
can someone explain the silvia setup in a bit more detail? eg what parts used, cheers
Posted on: 2008/2/20 5:31
1978 120y Coupe.
so nobody can help
Posted on: 2008/2/26 12:17
1978 120y Coupe.
From Brisvegas, oz
bundy351 has written a nice explanation in the tech section it explains everything
Posted on: 2008/2/26 12:26
www.camerasplus.com.au
« 1 2 (3) 4 »
