« 1 (2) 3 4 »
Re: Datsun 5-speed
From Beautiful Sunny (sic) Melbourne
5 speeds are getting pretty expensive in the US also. Most likely that's because they're a popular conversion for Austin Healey Sprites and MG Midgets.
60A on ebay US
The 63A is a bit less expensive on the whole but also less frequently seen on Ebay.
63A on ebay US
Whether these prices are a good indication of what you need to pay if you can find a gearbox I don't know, but they certainly make Australian prices cheaper than bringing a box from the US. New Zealand is probably the best option.
Posted on: 2008/2/4 1:51
Re: Datsun 5-speed
From Eureka,California
I'm a little confused.... What's the differance in converting a B210 with a
"60" vs. the "63"?
- Doug
Posted on: 2008/2/4 5:35
Re: Datsun 5-speed
From Christchurch NZ
I've done my level best to break my old 60, and It just wouldn't die. I think 60's are under rated.
The kicker is that they are so old now. The oil leaks out, or becomes contaminated. Then they begin to get noisey. It's not too hard to replace the bearings in them though.
Posted on: 2008/2/4 5:42
Forced Induction!
Re: Datsun 5-speed
From Launceston, Tasmania
Hello everyone,
I have some very good news to report,
I have just picked up the overdrive 5-speed
(normal shift pattern) 60 series.
It cost me $800, which I think is quite reasonble, for something so rare, and the difference it makes is very pleasing especially on the highway.
ie lower engine revs, better fuel economy
Re: Datsun 5-speed
From South Brisbane, QLD
Well if you find another one let me know...
Posted on: 2008/2/4 5:47
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
Re: Datsun 5-speed
From Burbank, CA
If you had a 1977 B-210 hatchback it probably had a 63a dogleg box, why dunno, that 1 year they decided to go way overkill on the transmission.
the differences are the shift pattern, the clutch slave is on the other side, the 63a is heavier and built a little stronger. It uses a different, larger output shaft, like the automatic tranny.
Other than that they're the same, basically. if you had a 1200 it would be annoying to fit, but since all 210's had an "automatic" transmission tunnel ( they were all big enough to fit an auto ) it's more or less a direct swap.
there was possibly a 63a with a 1:1 5th gear instead of the overdrive 5th that's common.
The wiki has a table of how much power the 56, 60 and 63 boxes can handle.
Posted on: 2008/2/4 5:48
|||\ 81 KPB310 /|||
Re: Datsun 5-speed
I'm trying to find out what all I'd need to do to convert a '78 B210 with a 4 speed,
to a 5 speed from another '78 B210 that I bought,or would a 210 be a better way to go?
- Doug
Posted on: 2008/2/4 5:57
Re: Datsun 5-speed
From Burbank, CA
you need a 5 speed and maybe a different tranny mount, other than that the 4 and 5 speed are the same.
a B210, 210 and RWD 310's are virtually the same chassis wise, and only a little different than a 1200.
Posted on: 2008/2/4 6:01
|||\ 81 KPB310 /|||
Re: Datsun 5-speed
What about clutch discs & drivelines?
- Doug
Posted on: 2008/2/4 6:02
Re: Datsun 5-speed
From Selah, Washington
angliagt
Doug, didnt you buy a B210 with a 5spd?
The clutch disk is different from the 4spd and so is the rear output.
Mike
Posted on: 2008/2/4 6:09
« 1 (2) 3 4 »
