Custom made fuel injection manifold
Not too shy to talk
From Gracemere QLD
i am just womdering i am starting to make a intake manifold for my morris with a Datsun 1200 motor in it and i am wondering if there is any specific size the plemume and runners have to be to make it run properly or is it just make it a resonable size say 3 inch or 4 inch pipe into runners that have injectors on them
Any help is appriciated
Posted on: 2008/2/19 6:00
Re: Custom made fuel injection manifold
From Newscastle, Australia
if its a stock A12 then 3 inch runners is fine. I would use a camira ecu and throttle body and build the plenum around that. The camria ecu can also be remapped if need be. Use the camira injectors also...
Posted on: 2008/2/19 6:52
Dont die wondering.....
From Christchurch NZ
It doesn't cover plenium volume, but there is some info on runner length here.
Posted on: 2008/2/19 8:17
Forced Induction!
From Christchurch
This website has a good article on working out plenum volumes and runner lengths etc, you want to read the article on induction systems
Click here
Posted on: 2008/2/19 8:37
From South Brisbane, QLD
Just had a look at that link that you posted nick and that info is GOLD.... Thanks.
Posted on: 2008/2/19 8:58
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
Not too shy to talk
From Gracemere QLD
so for an A12 i would need a pleneum 50 percent of my Cylinder displacement which is what???? and what size would my runners have to be and how round? all this maths is just confusing me?
THanks
Posted on: 2008/2/20 1:52
From Christchurch
Just ran the maths quick and for a plenum 50% of the TOTAL cylinder displacement i.e 600cc you could make your plenum out of dia 63.5mm(OD) x 3mm x 225mm long extruded round tube, or dia 60mm(OD) x 2mm x 225 Long would work too. PM me if you need a hand with the maths, i couldn't be bothered writing out all the maths :)
Posted on: 2008/2/20 6:40
Not too shy to talk
From Gracemere QLD
that just seems a bit a bit small to me has any one here made a intake manifold and what are the deminsions that you used and how did it work?
Posted on: 2008/2/21 2:12
Not too shy to talk
From Gracemere QLD
any help on how long the intake runners should be for a stock a12 and what size???
Posted on: 2008/2/27 1:20
From sydney
easiest way i would do injection on an a12 would be to buy a single sidedraught weber manifold, an injection perfection throttle body, and choose a computer of your choice, fire it up and drive away. simple quick bolt on and a tune. fun to be had all round, if you don't get the concept of what these guys are saying bout plennum sizes and stuff, then y try yourself, sorry to b blunt but thats the game with modifieing cars
Posted on: 2008/2/27 2:14
