1200 forgies
From Beautiful Sunny (sic) Melbourne
I've offered these before, and someone said they would buy them but never did. Anybody interested?
[img]http://datsun1200.com/modules/myalbum/photo.php?lid=7483[/img]
[img]http://datsun1200.com/modules/myalbum/photo.php?lid=7484[/img]
[img]http://datsun1200.com/modules/myalbum/photo.php?lid=7485[/img]
Posted on: 2008/3/5 0:30
Re: 1200 forgies
From Sydney
They look the goods, only if I could afford them.
Posted on: 2008/3/5 0:35
Re: 1200 forgies
How do you do that? I'm buggered if I can work out how to get pics into the post
And...they need to go to someone who'll use them so I am open to offers!
Posted on: 2008/3/5 0:57
Re: 1200 forgies
From Adelaide. SA
PM sent
Posted on: 2008/3/5 0:59
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
Re: 1200 forgies
PM replied to.
Forgot to add this info:
These are a balanced set of four ARIAS forged pistons a12 +040 with floating pins, teflon buttons, new rings. High comp - don't know how high - but there's plenty of meat in the crowns of the pistons so the tops could be machined off for a turbo application. These would be $1000 plus if you could get them (and if you were prepared to pay!). I'm open to offers.
Posted on: 2008/3/5 1:10
Re: 1200 forgies
From Las Vegas USA
I have got a set brand new of these (287-ss) and they are suppossed to be 12-1 compression ratio. Still haven't put them in because I'm not sure I want to be bothered with race gas. If I remember correctly Nissan called these "rally" pistons. Bprojects lists similar looking ones for something like $600 U.S. , I shudder to think what Arias wants.
Tom
Posted on: 2008/3/6 1:44
Re: 1200 forgies
Details: club article: Piston
* Ross Racing pistons: without wrist pins and domed for $391
* Venolia custom pistons: about $86.00 each
From the 1984 Nissan Competition catalog:
Nissan Competition does not recommend forged pistons for street use.
ARIAS FORGED RACING PISTONS
All of the forged pistons are of the dome-top design. Modifications must be made to the spark plug side of the combustion chamber for proper clearance. The compression ratio will vary depending on the swept volume of the engine and amount of material removed from the cylinder head. Piston-to-wall clearance for forged pistons should be approximately.005" to .007". All forged pistons use a full-floating .750" pin retained by Teflon buttons. For this reason the A12 and A12A pistons require the use of the A12A connecting rod (12100-98500). Also, the A13 and A14 pistons require the use of the A14 connecting rod (12100-H7200). Because of the full-floating pin the small end of the rod should be sized with a clearance of .0006" to .0009". End gap for the top ring should be .012" to .015". The second ring should have an end gap of .010" to .013". Clearance on the oil scraper ring is not critical. Forged pistons are not recommended for street use
Posted on: 2008/3/7 3:29
Re: 1200 forgies
Update from Morrisun:Quote:
Checked with Arias on fordged pistons with press wrist pins and compression rings-$175.00 each US. 4-6 weeks for delivery. The good stuff always cost $$$
Morrisun
Portland Oregon
Arias Forged Pistons
Posted on: 2008/3/8 1:36
Re: 1200 forgies
From puerot rico
all of that is ture. but you need look up to you lifters too and your heads tooo. it cant be too much shave you lose at your top dead end and hit the pistons when you cam has big lift so check first.ther others trixs too like pistons from others car????? the best. all [tips] i am looking for some rocker panels inner or cpmplet set if you know of some let me know am in deed????? puerto rico racing
Posted on: 2009/7/21 21:39
Re: 1200 forgies
DD
are these forged???
Also do Arias do others for that price each???
$175 usd each aint bad considering new bike
pistons cost about that also.
Posted on: 2009/7/22 0:25
