Browsing this Thread:   3 Anonymous Users
Rack and Pinion on my 1200 sedan
From Sunshine Coast QLD
I know there has been big debate about rack and pinion and i have read plenty of info on the subject.I have been speaking to qualified steering and suspension guys in various places over the last 2 months and basically it boils down to getting the rack as close to size as possible to suit.FYI i have found a KB Laser rack is very close to the correct length and with equally shortened shafts looks like it will work.will post pics as it goes...
Posted on: 2008/3/1 0:29
Re: Rack and Pinion on my 1200 sedan
From windsor, sydney
hi maddatto just a quick hello and to tell about my 1200 ute with nissan micra power steer rack had to move the pivot point on the crossmember out about 20mm per side and shorten the outer arms on the rack but with the strut/brake/wheel setup im using it works out perfect. And yes i have increased the track abit and plan to run small flares
Posted on: 2008/3/11 0:42
From NZ
maddatto wrote:
...i have found a KB Laser rack is very close to the correct length and with equally shortened shafts looks like it will work.will post pics as it goes...
Approx what model year/s is a KB Laser? (Presume we are talking Ford Laser/Mazda 323?)
Posted on: 2008/3/11 9:46
From South East QLD
The starter motor position on a "A" series can be a problem with the steering spindal touching the starter motor on a R/H drive car
Posted on: 2008/3/11 10:30
true there isnt a lot of clearance but it does fit.i have some nice stainless universals lined up and will give it the clearance it needs.Being a KB laser or 323 i imagine it would be mid 80's or even a little later.Ots amazing how close to size it is but i still have to make the mounts and turn down the rack ends..not hard really..will post the pics when done..still working on the other mods..my mate in taiwan is sending me some new seats over in my next container..cant wait
Posted on: 2008/3/11 13:08
Quite a regular
From Kaiata
I, recall an article in a ccc magazine ih the seventies where UK Datsun gurus used a a BMC Rack in a KB110 race car...
Posted on: 2008/3/11 19:57
From Taupo New Zealand
Wow i would love to see that article! That was a damn good magazine, the only bad point was that there was too much euro trash and not enough Jap cars! Mind you every edition seemed to have at least one escort in it so that kind of made up for it...
On the BMC R&P note, a guy here in NZ was going to use a minor 1000 rack in his 1200 coupe. Don't know how far he got with it but he knows what he's doing and it sounded like a good option.
Posted on: 2008/3/12 5:36
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Burbank, CA
anyone tried a rack from a b11 sunny? there was a manual rack available, I had one in my beater car, that's the one part i miss.
theoretically, a b11 and a 1200/b210 are going to be about the same width and might be another option.
Posted on: 2008/3/12 7:57
|||\ 81 KPB310 /|||
sounds good about the sunny..i have a wrecker friend next door so i swapped the rack for some beers..cant complain at that money
Posted on: 2008/3/12 11:45
Quite a regular
From Kaiata
Forgot to mention the said Gurus were Janspeed ,if i find it ,will pass it on Datman....
Posted on: 2008/3/12 20:02
