a question for all the a series nut
From Brisvegas, oz
just wondering what lightened flywheels poeple are using on their a series (its for the a12 turbo)
Posted on: 2008/3/22 13:09
www.camerasplus.com.au
Re: a question for all the a series nut
From Portland OR. USA
Currently, on the slightly warmed up A12 stocker I'm using a sunny flywheel lightned to to the Datsun Comp guideline. It's about 6.25Kg. Sitting on the shelf is a B-Projects 2.7Kg chromemolly flywheel purchased for the big bore A15 project. The 2.7Kg flywheel will most likely find it's way onto the stocker well before the A15 is done...
Posted on: 2008/3/22 15:40
From The garage, NZ
the a12 flywheel is lighter from factory anyway so there isnt much point in going to the a14/15 ones. Just get the standard a12 one lightened properly by a few kgs. If you go to light like below 4 kg id imagine you'd get annoyed with it after a while.
Posted on: 2008/3/22 22:17
The flywheel from the A10 [1000] is the lightest stock flywheel to start with, but was drilled for a smaller diameter clutch.
Mine was lightened & re-drilled for the 1200 & later clutch. Comes in at 12 to 13 lbs & was just fine for street use. [about 5.5 to 6 kg]
Posted on: 2008/3/22 22:29
Love your Datsun.
Treat it well.
From sydney australia
what is the intended use for the engine. If it's for the street or drag racing, use the stock weight A12. If it's for circuit racing, lighten it & rebalance it a couple of kgs. For anything involving a standing start, the heavier the flywheel, the better the starting start. Flywheels store energy that is especially useful in moving a car away from rest.(traffic lights or christmas tree). A friends Hillclimb car uses the heaviest flywheel he could find & it's a supercharged engine.
Posted on: 2008/3/22 23:43
From Townsville, Qld
I've heard L series flywheels are stupidly heavy. You rekon the same principle should be applied to a L18 for instance? intended use is hillclimb and club level sprints
Posted on: 2008/3/23 1:30
From Brisvegas, oz
its for street and strip so i guess i might be sticking with the stock one
Posted on: 2008/3/23 2:55
From Bendigo, Victoria, Australia.
im using a 6kg one and have no complaints about drivability
Posted on: 2008/3/23 8:15
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
You have to think about what you are going to do with the engine. Street car, strip car or track car. The flywheel basically supplies counterweight force to the end of your crankshaft giving you your torque. Pre boost torque is vital for a small capacity street vehicle. Track cars that don't see any hills will not be as affected by a lighter flywheel than a hill climb car. A serious turbo car doing quarter mile work or drift work will love the light chromemoly job but if you put 200kg in the back of your ute and tried to get up a steep driveway you will have trouble.
Posted on: 2008/3/23 9:27
*sigh,
if only there was some sort of viscous type flywheel that could lighten itself at different points in the rev range of an engine
Posted on: 2008/3/23 10:53
