« 1 2 (3) 4 5 6 7 »
Re: Datsun A6 engine - 600cc
From Brisbane, Narangba
Nah to A15s together. 3000cc straight 8
Posted on: 2008/4/7 7:33
From South Brisbane, QLD
why not a guy did it with an early nissan engine, cant remember what type though... it was awesome and he twin turboed it... there is a thread on here about it, think its in off topic.
Posted on: 2008/4/7 7:46
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
From The garage, NZ
thats the L6 with two ka heads cut and mated for twin cam l series and dett'd it too
L31DETT
Posted on: 2008/4/7 7:53
From Castro Valley,CA USA
JCCS L31DETT photo + thread
He sure did it up neat and clean.
So, did he have to change the cam lobes to get cyl #2 to fire 360
Posted on: 2008/4/7 8:27
From Christchurch NZ
This reminds me of a photo I saw in a mag a while ago. At some car show, some Mopar enthusiests had a factory prototype of a four cylinder Hemi engine. Like a 265 hemi, but with only 4 cylinders. Much like the 1900cc 4cyl commodore engine. Only not a puss holden engine!
Posted on: 2008/4/7 8:47
Forced Induction!
reuby_tuesday wrote:
That really is a engineering work of art. Max points to this dude for making this work.
I am just at a loss as to why this would be better then just using the a12 for the job. The link is just the pics, so there is no explaination for the purpose. Pity, since it would be intresting to see the train of thought behind it.
Nice work though.
I wouldn't be at all surprised to discover that it was done, .... just because he could.
Maybe it was a slow day in the back shed.
Interestingly, this conversion couldn't be done so well to a 1974 or later engine as the distributor would be in the bit that was cut off. Other ignition arrangements would need to be made.
There are a couple of points that I would have liked to learn more about.
1. The crank does not use a slinger at the rear as did the original. Was this intentional?
2. How did he install a rear crank seal? Probably in the rear plate. EDIT, yes it is, pic 16.
3. How did he seal up the half a welch plug hole on the left side?
4. How does he start it? [no starter]
At least two other engines seem to have donated parts. The half a fan is from an A10, the flywheel looks like a heavier A14 item, which would be a big advantage in an oddfire twin like this, & the rocker cover is not from this engine as it was gray while the original is blue.
He also appears to have lead wiped the weld join on the rocker cover instead of using some more modern filler.
Obviously a very tallented man.
Posted on: 2008/4/7 9:04
Love your Datsun.
Treat it well.
From Finland
Heh, I know that dude. He do what he want while other people do what they can. At his site http://kuvablogi.com/blog/1249/23/ there
Posted on: 2008/4/7 10:29
________________
-70 Datsun 1200 Deluxe (LB110), -71 Datsun 1200 Deluxe (LB110), -72 Datsun 1200 De
From Burbank, CA
I looked at the site, it looks like the engine is going in a small tractor or some things of that nature... perhaps a dedicated water pump ... i have to wonder what he's up to... his name on the gallery is Diesel Homer
the site was in finnish i'll see what else i can find out from it.
i can say it's not going in a "car" or other motor vehicle of that sort.
Posted on: 2008/4/7 10:30
|||\ 81 KPB310 /|||
From malta
yep it will be better in english all the description since web translator didn't translate it all
Posted on: 2008/4/7 11:07
From Townsville, Qld
lolz at kick starting the motor
Posted on: 2008/4/7 11:24
« 1 2 (3) 4 5 6 7 »
