« 1 (2)
Re: HEAD GASKETS ON TURBO A SERIES
From The garage, NZ
nismo metal head gasket. multiple thicknesses up to 2.0mm im sure.
The goods in my opinion
Posted on: 2008/2/16 1:36
An A15 I had o-ringed. From memory the ring is 1 long piece covering 2 cylinders making a figure 8.
I will try and dig up a better pic.
Posted on: 2008/2/16 7:21
From perf
so where can you get the nismo or tomei product in ozor do you have to get it from japan?
Posted on: 2008/4/8 3:39
From cronulla
ask bige he has them
Posted on: 2008/4/8 4:09
From NZ
I use the genuine Nismo gasket which has a wire ring under the fire ring for extra 'bite'. (Note some have this some don't). It's on my 13:1 C/R A series race engine - no problems. Expensive but they don't blow. I'd suggest they'd be good for turbo too.
Posted on: 2008/4/11 12:00
From NSW, Australia
I would recommend to make your own copper head gasket.Or have one cut out. That way you get the thickness you want and quality too.
I had one made for about $80
No more gasket problems. Too Easy
Posted on: 2008/4/11 12:26
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From Freo
I can supply Nismo composite gaskets or Kameari Metal gaskets.. :)
Posted on: 2008/4/11 15:15
A15 PSI Project Motor
'72 CB750k,
« 1 (2)
