(1) 2 3 »
what can i do about putting upto 300hp through a A series gearbox
From Adelaide, Australia
hey guys have a E series turbo motor connected to a A series gearbox. i suspect in the future now that im getting forged pistons and a bigger turbo i will need to upgrade the gearbox. may have upto 300hp so what do i do to get some strength? is the celica 5 speed conversion strong enough?
Posted on: 2008/5/9 9:03
Re: what can i do about putting upto 300hp through a A series gearbox
From Canberra
depends how you drive it, if you smash 2nd and 3rd too often with that sort of power it wont last long at all.
Posted on: 2008/5/9 9:20
From Sydney, Australia
Don't change gears, and only use brand new gearboxes or gearsets. Basically even the best A-series blokes never put more than 200hp through their boxes.
300hp..tell him he's dreaming ..time to look for the delco 5 speed Toyota box conversion bellhousing..
Posted on: 2008/5/9 9:35
Quite a regular
From ADELAIDE, SA
The celica steel case 5 spd should cope with the power and torque.
Posted on: 2008/5/9 9:40
From Canberra
I dont think anyone makes a kit for steel case toyota 5speeds.
Posted on: 2008/5/9 9:51
Quite a regular
From Modesto, CA USA
I think you will need a t56 behind it :) jk!
Posted on: 2008/5/9 10:11
Daft Innovations
For ls1 swap parts for 240sx
Add me on Myspace For swap pictures.
From Geelong, Vic
or one of topgears straight cut gearsets....if any a series gearbox stands a chance it would be one of his
id say adapt a supra box to it
Posted on: 2008/5/9 10:19
From Canberra
Or get some sort of auto made up to suit... if straight line stuff is what you've built it for.
Posted on: 2008/5/9 10:38
How about a holinger SD6. Supercar box. Only $20,000. That should hold up!
Posted on: 2008/5/9 11:20
From The garage, NZ
a series boxes + ~300hp = epic fail
do it properly and do it once i say
Posted on: 2008/5/9 12:09
(1) 2 3 »
