CA18 Exhaust system - mine no good - ideas please
From Mandurah, Western Australia
People Im after some ideas for the exhaust on my 1200 Coupe with a CA18DET and input on what others have done.
WA Transpost has stated my exhaust does not comply with the new regulations released last month for exhaust systems as it has inadequate clearance. Must have a minimum of 25mm from the underside of the body in all places. At points like above the CAT and near the rear shock obsorber I have only 10 - 15 mm.
I have a 2.5 inch system. A high flow CAT is under the passenger footwell, A Resonator before the diff, the pipe goes over the diff and has a cannon muffler at the rear. Custom rubber mounts have been used and despite the low clearances the system can not hit the chassis or any components on the vehicle.
I feel it is bloody hard to install a modern style exhaust system on the 1200 coupe given the design and size of the original vehicle.
So my question Is for others with the CA transplant. How did you make your exhaust and how much clearance did you end up with?
Sadly it looks like I will have the expense and pain in the arse of making a 1.5 inch system with all new components to satisfy the beurocrats.
Cheers - Because I need a drink.
Posted on: 2008/6/4 14:43
Re: CA18 Exhaust system - mine no good - ideas please
From Geelong, Vic
hammer + floor = clearance
Posted on: 2008/6/4 14:47
why not a twin 2 inch after the cat to the rear muffler then use the same muffler at the rear. should still push out more air than a single 2.5
Posted on: 2008/6/4 22:40
From perth airport
i have a 3inch ss zorst with one cannon at the rear and when i get to go over the pitz ill get a 2inch or 1.5 inch zorst made up
its best to have two exorst's one for the pitz and one for the day after the pitz
Posted on: 2008/6/4 23:18
perth airport parking
Datsun 1200 ute A14
Maybe use a reducer after the resonator to allow running smaller tube over diff to a different muffler.Throw the CAT away!
Posted on: 2008/6/5 6:18
From South Brisbane, QLD
Probably cant throw the cat away because the ADR's that came out on the year of the engine probably state that it has to have one...
Posted on: 2008/6/5 6:37
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
From Far, far away
Damn right Mitch....no CAT is a big no-no!!
Posted on: 2008/6/5 6:41
From Melbourne AUS
WA Transport?
who?
I bet the mojority of new cars wont pass that rule.
Posted on: 2008/6/5 8:32
1973 B110 A12
From Adelaide, SA
mine is 2 1/2" with a cat and a muffler it is fairly quiet but has a nice note and is legal. it good cos doesnt draw attention. probably a little restrictive though.
Posted on: 2008/6/5 9:24
