What breaks in a 56A gearbox??
From Ballarat Victoria
Hi all,
When these gearboxes break, what usually lets go?
Thanks, Simon.
Posted on: 2008/6/15 5:57
VIC DYNO HIRE
Re: What breaks in a 56A gearbox??
Chipped teeth on the cluster gear.
Posted on: 2008/6/15 6:19
From NZ
Std/mild engine - nothing/not much.
Torquey/Modified engine - stripped gears - treat with care.
The later 120Y/Sunny version (1" clutch cable hole) is stronger than early 1200 version. Its gears are a bit wider and bearing set-up differs.
Posted on: 2008/6/15 13:09
Thanks guys,
So usually the gearset.. has anyone had a split case or selector issues?
Posted on: 2008/6/15 13:29
VIC DYNO HIRE
From Perth WA
Yeh ive stripped teeth on one before.very mild A12 did it too
Never had a selecter issue, And i have pretty much no bushes left on the lever. Still smashes in beautifully!
You got probs with yours or just researching?
Posted on: 2008/6/15 13:39
Chris...
No problems yet.. I bought a 56a box with a "Topgear" gear set some time back.
Im going to try it in the coupe and was interested to see even if the gearset has been changed what other issues i might have with it.
I`ll only have a standard box as a spare so
it might have to get me through a race or two. I`ll have to wind back the HP for that though.
Posted on: 2008/6/15 13:56
VIC DYNO HIRE
From Darwin NT
topgears straight cut box?? goodluck on breaking it
its just the 56a casing he used for the lightweight of it the internals are all custom made by him so i dont think you will break it in a hurry!
Posted on: 2008/6/16 0:22
current project 4x4 patrol...
From Townsville, Qld
I had balance shaft bearing failure in my 56A box, what started it off though was ONE flatshift gone wrong in my standard 120Y at the time. it acually lasted over a year like that until one arvo I went to impress some people and hit some dray road, the box went BANG!!! so i reselected and limped over to Ian's workshop
Posted on: 2008/6/16 9:58
