please help
Quite a regular
From south australia/ adelaide
hey
does any1 know if the L20 motor out of a 200B fit into a 1200 ute? and what about the struts out of the 200B into my ute aswell??
thought use people would be the best to ask, dont wana go and get a 200B and realise the stuff doesnt fit. haha. cheers guys
Posted on: 2008/6/16 13:42
Re: please help
From Adelaide, Australia
Definitely not bolt in, but you don't need to hack your car at all to fit it in.
<------------------ do a search to find out more, any questions you may have don't hesitate to ask.
I have L16s in two of my 1200s and unless you have a welder and the know how then you probably shouldn't do an engine conversion really.
Posted on: 2008/6/16 14:02
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: please help
From Perth Western Australia
been done a few times on here, and once by me.
L20b is a tall motor and so it is a little hard to get it under the bonnet. You can either cut the sump down, or dish the crossmember (probably a better idea). Needs custom engine mounts (obviously) and tunnel will need modifying. I just cut the tunnel out of the 200b and welded it into the ute, but there's plenty of other options including buying the prefab tunnel from maddat ( i think they do them)
anyway here's some reading material:
link1
link2
link3
link4
check out my photo album too, i think there's a couple pics in there...
sorry, can't help with the 200b struts.
Posted on: 2008/6/16 14:05
Re: please help
Quite a regular
hmmm. gotta have a think about this. if im gana do all the messing around doin the converion, i might just wait and go something bigger. but for now i really want better struts and brakes??? i dont know what will bolt in? anyone else know if anything bolts in easy? hopefully goin to pick up most of my parts 2moro:) decided to replace every single panel on my ute except radiator support and where the tail lights bolt in. goin to pick everything up except my new doors arent in yet.
what about any other datsun motor that will go in thats bigger than the 12a but not too much messing around to do it?
thanks heaps for ya help guys.
Posted on: 2008/6/16 14:12
Re: please help
From gold coast aus
either an a14 they are in some sunnys or a15 which you can get out of a vanette use the same gearbox as a12 all are a series engines
Posted on: 2008/6/16 14:25
Re: please help
Quite a regular
ok cheers for the help. i forgot all bout the a14 n a15. do they bolt in the same? i dont mind playin around a bit but i dont wana muck around to much until i do a proper conversion. hmm now the hard part of trying to find a cheap one. hmmm
thanks
Posted on: 2008/6/16 14:35
