« 1 (2) 3 4 »
Re: kb10 diff conversion
From Melbourne vic
yeah D there is a few common
crownwheel and pinnion ratio's
including 4.11 & 3.78:1 for sprintcars
and a multitude of transfer gears
available giving ratio's
of anywhere between 5:1
& about 8.5:1 depending on
whats required for track size
Posted on: 2008/6/23 11:04
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
yes thanks and just found the Hallibrands are available to 9.11
Posted on: 2008/6/23 11:05
From Melbourne vic
yeah it's pretty cool, halibrand is more old
school now with 800+ hp ratio's
like that are not required so much,
on big tracks in the states they don't
go much above 6:1!!!
Posted on: 2008/6/23 11:16
:Nice
From Melbourne vic
although D and i went a bit off topic
it appears as though the bluebird
seems to be the go for price, availablility
strength and simplicity-cool
Posted on: 2008/6/23 11:31
:Nice
I heard there are 200 auto bluebird wagons circa 84-85 that have australia post paintjobs and lsd in them. So when u are at some wreckers and spot one think big!
Posted on: 2008/6/23 11:36
The 910 Bluebird was built as the L series powered Series 2 up untill January 1985, then as the series 3 with the unloved CA20 engine from February 1985.
The series 2 wagons with Auto's & with 5 speeds used the H165 while the poverty pack option with the 4 speed gearbox had the H190.
All of the series 3 cars had the H190, so I am at a loss as to which "Circa 1984-'85" wagons you are refering to.
Posted on: 2008/6/23 11:43
Love your Datsun.
Treat it well.
From Oberon NSW {Bathurst}
Why not go all the way! Chop down a 9inch, fit a Mark Williams centre, a set of Richmond gears, some 31 spline hollow axles drilled for Datto PCD. (Available from Driveline Services) Worked well in a blown 383 72 Hemi Cuda. I know it's late and I'm getting old and senile
Posted on: 2008/6/23 16:11
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
From Geelong, Vic
coz a 9 inch defeats the purpose of having a 1000
bluebird h165, or h190 if you really need strength, cut down about 200mm (got measurements somewhere) should do the trick
need to use the larger drums off the bluebird though so may not be able to fit 12s, or you have to get the axle flange machined down in size to suit 1200 ute or 120y drums
Posted on: 2008/6/24 2:44
From Darwin NT
pigdog do you want to shorten my diff and redo the mounts?
Posted on: 2008/6/24 3:05
current project 4x4 patrol...
Well said Pigdog a 9 inch needs like 8hp just to turn the bloody things!
For a K as soon as any part is 25% heavier than the original its rooted.
[size=medium][color=000099][font=Impact]
Posted on: 2008/6/24 3:44
« 1 (2) 3 4 »
