If you go with a bore to big like 40mm or 42mm you will lose air flow properties...the smaller the bore the quickest the air rushes in when you fully open the throttle...
Look at this quote:
" A. What is the best throttle body diameter?
Factors influencing size are: Power output, rpm, cylinder head design, cylinder capacity, position of the throttle body in the inlet tract and position of the injector.
Choice of bore size is a balanced compromise resulting from the following:
1) A larger bore leads to lower flow resistance, but obeying the laws of diminishing returns.
2) A smaller bore leads to better throttle control and response (never underestimate) and improved fuel mixing.
3) The system should be considered in total - from (at least) trumpet flange to cylinder and proportioned accordingly.
Basic references for BHP per cylinder, assuming ca.(ca.= approximately) 120mm from butterfly to valve head and a max of 9,000 rpm are:
Up to 30 BHP/CYLINDER - 30mm
up to 33 BHP/CYLINDER - 32mm
up to 39 BHP/CYLINDER - 35mm
up to 46 BHP/CYLINDER - 38mm
up to 51 BHP/CYLINDER - 40mm
up to 56 BHP/CYLINDER - 42mm
Up to 65 BHP/CYLINDER - 45mm
up to 74 BHP/CYLINDER - 48mm
up to 80 BHP/CYLINDER - 50mm
up to 87 BHP/CYLINDER - 52mm
up to 93 BHP/CYLINDER - 54mm.
These power figures may be increased by up to 10% in a purpose - designed, well proportioned system.
As butterfly to valve distance increases, butterfly size will need to increase in proportion to system taper and vice versa.
Lower revving engines and those with injectors placed before the butterfly will generally accept a larger body. "
from the web page:
ITB's info Site I also have a book that explain all the whole air flow stuff...so my question is...i know there are a lot of people runing 40mm and 42mm and 38mm...but is it runing at maximum eficiency? are you getting all that you can out the the ITB's?
Big isn't always better...thats why we drive Datsuns and not Mustangs! hehe
