Browsing this Thread:   3 Anonymous Users
(1) 2 3 4 »
L series conversion query?
Looking at the tunnel mods required so far to get my head around this. I know what tunnels other fit eg, stanza, 180 b etc for using a stumpy gear box but wondering if a 120y one can be used as i have access to one free and 120y's came with L series in Japan.
Doubt they would have used a different tunnel seeing auto and manual 120y tunnels are the same.
Posted on: 2008/8/15 3:25
Re: L series conversion query?
From Armidale N.S.W
Do you have an Auto tunnel ? If not i would imagine that the L series 4 speed is to big for an A sereis 4 speed Tunnel. Though I'm no Datsun GURU.
Edit You have access to what a 120y tunnel ?
Posted on: 2008/8/15 3:29
73 1200 wagon SOLD
From Brisbane, Australia
what car are you putting it into?
120Y tunnel should have no problem accomodating an L series box.
1200 manual tunnel needs slight massaging around where the tunnel meets the firewall
and you might need to remove the mounting brackets inside the trans tunnel for clearance. I didn't need to with the Stanza 5spd but when I changed to a stumpy Skyline box I did.
Can't comment on a 1200 auto tunnel - never had a 1200 auto...
Posted on: 2008/8/15 3:37
sorry its a manual 1200sedan,
suprised a stanza gear box fits no worries but stumpy doesnt? thought the stumpy was smaller?
Posted on: 2008/8/15 3:42
From Melbourne Aus.
yeah just massage the tunnel around the lip and the bottom passengers side is its a 1200 manual.' auto's are fine as I had a auto as a test rig but when I installed everything into a manual I had to massage the tunnel. It's because the stumpy box does not taper back after the bellhousing as sharp as the 1200 box.
Posted on: 2008/8/15 5:02
From Geelong, Vic
stanza box is the smaller stumpy mik
so next weekend ill give you a sledge hammer and point you in the direction of the ute, or coupe which ever is closer, and you can see how much it will move
Posted on: 2008/8/15 5:35
yeah Stanza boxes are the same length as the stumpy box but slightly narrower.
it will move surprisingly easily - I've done it to a coupe and a sedan with a 2lb club hammer. Doesn't take anything like the force you probably imagine. sledgehammer is total overkill!
Posted on: 2008/8/15 6:37
From Geelong, Vic
takes a sledge hammer after its crumpled into a stronger shape, thats about the point where my tunnel got cut out
Posted on: 2008/8/15 6:47
will attempt it on you ute then, but i have a feeling the rust wnt hold together
I will tap tap tap it in. The home is your hole, go in the hole.
Posted on: 2008/8/15 6:51
From tasmania
I am only running a 4 speed behind my l 18 it had a manual tunnel in the car. when I seen the amount of bashing I had to do I took pigdogs advice and cut the tunnel out the end result I think, a far better job.
Posted on: 2008/8/15 9:24
(1) 2 3 4 »
