« 1 (2)
Re: FINALLY BOUGHT A 1200 ute
From Rosewood, QLD
Mitch im doin 4000rpm at 110kph im not sure if its a good idea to stay at this rev range on trips to Sydo lol it cant be good for her maybe i have to lower the diff ratio to get more out of each gear.... how is this done?
Posted on: 2008/8/16 1:34
1971 B110 sedan project.
2012 Nissan Micra daily.
From Melbourne, Oz
a "rally" box will be close ratio and it wont hav overdrive still just 1:1. and then its a ute so its probly got a 4.11 dif. and mate I sugest you do hav a closer look at the year because if it 75 and up it will hav a stronger diff.
And on the other note. I'v had my sedan past 100mph I think it was doing not quite 7g's on stokies with a 4speed. and I think when its siting on 60mph/100kph its doing about 3500rpm?
Posted on: 2008/8/16 1:54
"I hav achieved wood"
From South Brisbane, QLD
ZigZag, I dont like to drive my'n at higher RPM for to long either... But at 8000RPM she does sound lovely... not sure what rpm I'm doing at 160, I will look next time.
Um, just have a look in the wiki under drivetrain modification then diffs there is a few options but centres can be hard to find. The other option is a 5 speed but thats expensive and hard to find....
Posted on: 2008/8/16 1:55
Skyline Productions
1985 Datsun 1200 ute, trailer trash.
1994 Suzuki Sierra, weekend warrior.
From Sydney
A-series are very comfortable are running at 4000 RPM for sustained periods of time. I drove my A12 powered sedan to datnats 07 [Philip Island Victoria] from sydney. It was travelling at 4250 RPM for hours and hours. Good oil, spark and cooling and the A-series will never let you down.
Posted on: 2008/8/16 1:56
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Rosewood, QLD
Mitch what kind of cam, lifters, valve springs and bottom end have u got to be reving at 8000rpm? thats nuts dude
yeah im looking at a shortened R30 LSD to replace my current diff even though its the H165
Posted on: 2008/8/16 2:12
From Las Vegas USA
The standard GX valves spring won't float until 8100 RPM's and as the motor is non interference fit not to worry.
As for sustained RPM's back in 1985 we did a road trip with the coupe and for 2 1/2 hours it never went below 5000 RPM's and for 1/2 an hour of that it was at 6000 RPM's down a lonely stretch of desert highway. Basically if you drove around Bonneville Salt Flats in a giant 5 mile circle an A Series motor would likley run 20,000 miles nonstop at 6000 RPM's
Also as said a "rally" box is 1:1 top
And congrates on your new purchase!!!!!
Tom
Posted on: 2008/8/16 2:22
From Rosewood, QLD
ok then so i shouldnt worry about reving between 4000-5000rpm? thats sweet!!! i been avoiding the highway a bit... ive heard the celica 5 speed is the best option for box upgrades and a better diff ratio will help heaps
Posted on: 2008/8/16 2:40
« 1 (2)
