locked myself out of the house the other night ...
as the title suggests i locked myself outta the house the other night, leaving me 2odd hrs to fill while waiting for my g/f to get home ....
soooooooo i started to hunt around in the garage and i found my datto !!!! and a few bits and pieces ...
my south african alloy rocker cover seemed to fit ok .... but when i pulled off the blue steel one to test fit it, i found my rocker gear ...
which came off easy and found its way to the bench ... and some of these ....
which found their way back into here ...
and then to top it all off something arrived today that i'd been waiten for ....
and when you pull the switch ...
..... thanks Nick for the motorvation while standing around and the link to the lights
Posted on: 2008/9/5 12:31
Re: locked myself out of the house the other night ...
From Sydney
looks the goods.. wat is the clearence between those spaces and rocker arms supposed to be?? is it hard to set up? as i recall the rocker posts can be boltted down small amounts to the front or back due to sloppy tolerences does this affect clearences??
Posted on: 2008/9/5 12:43
not sure on clearances ... but as i bolted the posts down i made sure there was enough play for the spacers to spin freely by finger between the rocker arms ... they've been machined spot on right around. i dont think you could get matching clearances on each side of everyone but if they move free enough there shouldnt be any issues ...
they are BProjects gear thru Dundee in WA.
Posted on: 2008/9/5 12:53
From Perth WA AUS
Yeah Dundee supplies the good parts, Kick ass setup on the car, I love it!
Posted on: 2008/9/5 13:15
Datsun 1200 2Dr sedan.
From Christchurch NZ
That rocker cover is pure porn.
Posted on: 2008/9/5 22:50
Forced Induction!
the chain saw will come in handy too.
did you work out the munt for the accel cable on the new rocker cover yet?
Posted on: 2008/9/5 22:54
From Geelong, Vic
so the headlights didnt melt or anything when you turned them on? turned mine on last night and there must have been some kinda coating on something that started to smoke a little....will sus that out once they are on my car
then gotta figure out how to get rid of the fingerprints
Posted on: 2008/9/6 2:31
From Brisbane
Where did you guys get those headlights from? and how much? they're not the projector style right?
Posted on: 2008/9/6 3:18
It all looks very neat boofhead.
Those headlights are fantastic, is this the same A12 on your youtube video doing the burnout? It sounded pretty good.
Like the rocker-cover too, what interests me is the "DATSUN" part is the almost the same cast as the B10 guard badge.
What make is the intake manifold and did you make your own air cleaner housing? It looks like it's a shared air cleaner.
The throttle shaft is pretty long too it's almost touching the firewall. You should put the throttle lever of the first carbie onto the outside- closest to the radiator.
Posted on: 2008/9/6 4:36
From Townsville, Qld
I'm having a look for those headlights but I came up with these, they're pretty cool too
headlight covers
Posted on: 2008/9/6 5:19
