Pod Filters
From gold coast QLD.
Being an old schooler and having a need to organise a pod filter for the CA Turbo,anyone have a preferance in makers?
Cheers
###t just noticed i picked up another star!
Does that mean i've talked crap more than a thousand times?
Posted on: 2009/1/20 6:17
Re: Pod Filters
From newcastle, NSW
There is alot of pod filters out there, most of them are for show, you know the bling factor, your local spare parts place should have about a thousand! all colours and shapes! a good quaility like a K&N pod filter should be fine.
You're a Dato master now Burt! congrats!!!
Posted on: 2009/1/20 6:28
Re: Pod Filters
From Sydney
If you want a paper type filter pod, then you cant go past K&N, If you want a foam type pod, then I would recomend 'uni-filter"
Posted on: 2009/1/20 6:39
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: Pod Filters
From Mandurah, Western Australia
I have used k&n numerous times and these are a cotton style filter which I would recomend.
Brought a supercheap copy on k&n for the datto as it only $20 and use the k&n cleaning and oil product on it. Did not pay the extra $$$ as this car sees minimal use.
Posted on: 2009/1/20 7:00
Re: Pod Filters
From Perth WA
I bought the big K&N oval pod for around 200$, only because of swirl and airflow meter problems using round ones.
I reckon its overpriced and cleaning it is time consuming, foam type best for keeping fine crap out, breathing well and lot cheaper i reckon. unifilter has good rep.
Posted on: 2009/1/20 7:07
Re: Pod Filters
From Freo
K&N have the reputation, good value and quality..
Posted on: 2009/1/20 7:10
A15 PSI Project Motor
'72 CB750k,
Re: Pod Filters
From Perth WA
congrats ur a made man now bert
Posted on: 2009/1/20 7:11
Re: Pod Filters
I run the Foam Filter socks from Unifilter.
Uniflow/Unifilter
As for pod filters K & N take it. Although I haven't tried any other brands.
Have a browse Uniflow might make the solid pod types too.
EDIT: Yes they do! They call them the straight pod and Angled Pod. I would go with unifilter. Easier to clean, cheaper.
Posted on: 2009/1/20 7:16
Re: Pod Filters
From South Africa, Bloemfontein
Would recommend paper one over foam one.
Posted on: 2009/1/20 7:20
1977 Datsun 1200GX
Re: Pod Filters
Thanks guys,looks like K&N seems to be your preferance,it's not overly important what size the inlet is?This is a whole new learning experiance.
And yeah, that Dattomaster thing crept up on me
Posted on: 2009/1/20 7:22
