Stabilizer bar
Hello All.
I have a Coupe B110 that I am preparing for gravel Rallying. I have mocked up the following set up on the front on it. Stanza Lower Control Arms. Stanza Stub and Hub. Can someone tell me what Stablizer bar can be used with this?
Thanks.
Posted on: 2009/3/30 22:10
Re: Stabilizer bar
From Townsville, Qld
Well you could use the B210 or 310 bar but a few of the people I've come into contact with don't run a front swaybar for certain gravel and forest events. It really depends on how well you're going to setup those struts.
Posted on: 2009/3/31 0:30
Re: Stabilizer bar
I would think the B310 stabilizer bar would fit up to the Stanza arms. And maybe the Stanza bar.
B210 bars fit a stock Datsun 1200 and are a good upgrade if you need stiffer anti-sway in the front (most street 1200s do).
Posted on: 2009/3/31 0:58
Re: Stabilizer bar
From Geelong, Vic
stanza and sunny sway bars are too wide, pretty sure a 120y sway bar is just as thick as them anyway
Posted on: 2009/3/31 1:38
Re: Stabilizer bar
From Adelaide
120Y bar is 19mm and the 1200 bar is 17mm, both are the same shape and can be interchanged.
Posted on: 2009/3/31 2:59
Re: Stabilizer bar
Thanks for the posts guys.
The problem I am facing is I have to buy a 120y (B210) sway bar that is non refundable. So I need to know for sure that this will fit on the Stanza LCA's and Stanza Sub axle assembly.
I have seen the post on the Upgrade in the Struts Section to Stanza but it does not mention anything about the Sway Bar used.
Can anyone please confirm this for me.
Thanks.
Posted on: 2009/3/31 12:40
Re: Stabilizer bar
From Mandurah, Western Australia
I have a B110 - 1200 Coupe with Stanza lower control arms and ball joints. Plus the Stanza Struts. Anyway the 120y will fit with no probs.
Where are you located??? If in WA I have a 120y Stabiliser bar and a 1200 Stabiliser bar. $20 each.
Posted on: 2009/3/31 12:53
Re: Stabilizer bar
Thanks for the response "Old-School" ... i am on the otherside of the world! United Kingdom. We are doing a restoration on a B110 Coupe. But for that price I may just fly to AUS! The Datsun parts in Uk don't come cheap! Many thanks for the offer though!
Posted on: 2009/3/31 21:29
Re: Stabilizer bar
From Sydney, Australia
If you are running an a-series..it will definitely fit. But you need to get bigger D-clamps and rubbers to fit them. Getting the parts off the 120Y helps.
It is unlikely to fit if you are running a CA18.
Posted on: 2009/3/31 21:33
Re: Stabilizer bar
From Sydney
120y sway bars came in 17.5mm and 20mm
so when replaceing make sure you get the right size D-bushes
Posted on: 2009/4/1 0:01
