DOOR HINGE SLOPPY
From Albury
The door hinges on my little ute have got a fair bit of play in them. Is there a kit available to rebuild them ? What did you do to remedy them
Thanks
Bob
Posted on: 2009/4/24 11:36
Re: DOOR HINGE SLOPPY
From South Africa, Bloemfontein
Remove door hinges and get them rebuild at a local engineering shop. That is what I did.
Now I can close any of the 4 doors on my sedan with the use of one finger.
The pin gets worn that the hinge swings at.
Posted on: 2009/4/24 12:37
1977 Datsun 1200GX
From Mandurah, Western Australia
As Im sure you are aware its a 2 piece hinge with a pin joining the two together. In one of the pieces their is a plastic slieve/collet which wears out.
To my knowledge this plastic part is NLA. However I knoced the pin out and machined up 2 new brass slieves on the lathe and it works a treat. You could use nylon. Its a 15min job for someone with access to a metal lathe.
Posted on: 2009/4/24 15:51
From Christchurch NZ
or, you can just adjust the hinges against each other to remove the free play. That ussually lasts long enough to pass a roadworthy, or sell the car. lol.
Posted on: 2009/4/25 23:31
Forced Induction!
You can buy new hinges just not the rebuild kit.
Posted on: 2009/4/26 0:09
From Tamworth , NSW
you often see them on ebay, the only drawback is that postage is just as much as the hinge and you will pay in excess of 100aud per hinge.
Posted on: 2009/4/26 0:22
From Albury
thanks for that rebuilding them with machined up spacers sounds the go
Bob
Posted on: 2009/4/26 6:09
i just got my coupe ones re-sleeved by my brother hes a fitter and turner, as far as i know its just nylon...
Posted on: 2009/4/26 6:51
