Browsing this Thread:
1 Anonymous Users
PerTronix Ignitor & Coil |
From Cape Town, South Africa
Going to install Pertronix Ignitor to my A14.
I have a few questions?
Heard a few people saying that the standard coil will be good. Others say the ballast resistor need to be removed as it is only there to reduce volts to around 8v for the points. Others have stated that you need a electronic ignition coil.
Who to believe? Any better help than these okes?
Pertronix suggest using there coil, well 40 000 Volts sounds good and it shines, but what is the real performance increase on a mild tuned motor? If you search around forums, everyone says MSD Blaster 2, but no one can actually state the pros & cons of a high performance/volt coil. It seems that people heard MSD is good and use it as a "I have a MSD coil, it is red and shines, your one is silver and dull" kind of approach.
Can someone state the real reason for using a high output coil and what the benefits is to a mild tuned motor?
Posted on: 2009/4/24 13:28
Re: PerTronix Ignitor & Coil |
From South Africa
If your points are set up well youll notice about nothing when fitting the Pertronix, BUT it does make maintance easier and cheaper once its fitted.
As far as coil, doesnt make much difference, most of what people claim is in their imagination, We tested 7 different coils way back on a mildly tuned 350cid and they were all within 1-2 hp of each other... now changing to a MSD CD or similar does make a noticable difference, especialy mid range and fuel consumption.
One thing to be very careful with is fitting a hard core low ohm coil (ie the blaster SS) to the pertronix, you land up having to run a massive ballast resistor (1.6ohm), if you dont youll pop the pertronix.
I would say for regular mild motor just run the pertronix on the stock coil unless it fails.
Posted on: 2009/4/24 14:12
'75 1200 B110 - 154hp Race prep A14 '97 Silvia - 600hp SR20 time attack '07 Hilux - Tow car
From Sydney
If i remember correctly the pertronix instructions say to leave the standard ballest resistor and the standard coil can also be retained. Speaking about coils, a lot of people do not like to use the standard type coil as they are oil filled and can leak. Newer style coils are more compact have greater output and not oil filled.
Posted on: 2009/4/24 14:52
Quite a regular
From Hartswater South Afrika
I toke an hallsensor from a vw with a vw ignition module and an normal elecronic(bosch)coil,just a bit of work but at the time it was all i could get
Posted on: 2009/4/24 17:07
sparkyza1,
Is it possible to explain more in detail what you did. Any wiring diagrams and part numbers will help.
Posted on: 2009/4/28 8:34
Rezlo,
Thanks for the heads up, glad to see someone agrees with my "It's red and shines" theory about a high output coil. Had a chat with a clubmans racer over the weekend, he suggest a VW Bosch coil, majority of the clubmans racers use those, as it doesn't cause problems, they are running highly tuned motors in the 140-160kw range.
Posted on: 2009/4/28 8:39
From South Africa, Bloemfontein
I have a Pertronix ignitor running the standard coil. I can't remember if I removed the balast resistor, I will have to double check. But I am running the standard coil. No problems and I have picked up the car idle's more smooth and a little better fuel consumption and power more stable at higher revs. I would definitely recommend it.
Posted on: 2009/4/28 8:57
1977 Datsun 1200GX
1200GXman,
Please let me know about the ballast resistor?
Posted on: 2009/4/28 9:02
Registered Users Contentmaster Usermaster
The coil and ballast resistor are a matched set. It has nothing to do with the Pertronix
* If your coil requires a ballast resistor, keep it. * If your coil never used a ballast resistor, don't add one.
Just make sure your Pertronix can use a straight 12V coil, which draws more current and will burn out the lesser Pertronix unit. Some Pertronix kits can, others cannot. Read the instructions to know for sure. If your Pertronix requies a coil with ballast resistor, get a matched set (coil + resistor). Don't add a resistor to a high energy coil.
Posted on: 2009/4/29 4:02
Update: Yes, mine is connected to the ballast resistor.
Posted on: 2009/4/29 6:46
1977 Datsun 1200GX
