cam grinds?
From northern 'burbs adelaide
what would a suitable grind for a supercharged application be ... looking to go all out here
Posted on: 2009/5/23 13:14
Re: cam grinds?
From Melbourne, Oz
The cam grinder will be able to grind it to make power were you want it, you wont need to no the spec's??
Posted on: 2009/5/23 13:53
"I hav achieved wood"
Re: cam grinds?
ok then ... how bout, does anyone know a decent cam grinder in adelaide that i can discuss this with as the only places ive talked to do set cam grinds and they arent anything special either
Posted on: 2009/5/23 14:42
Re: cam grinds?
From Freo
high lift short duration..
Posted on: 2009/5/23 16:41
A15 PSI Project Motor
'72 CB750k,
Re: cam grinds?
High lift, low overlap. Which is shorter duration than a typical 'race cam'.
Find a cam grinder that does custom grinds. They'll no what to do. Don't they have any in Australia? In New Zealand there is Kelford.
Posted on: 2009/5/23 19:44
Re: cam grinds?
From Adelaide S.A
I use wade cams, they can regrind your old cam to whatever specs you choose. You want lobe seperation angle of 114+ degrees and duration as large as the power range you are chasing, lift as much as your valve train can handle without coil bind or piston to valve clearance. Dont be afraid to go as large as 230/230 @ 50 if your chasing good power @ 3000rpm+ and have good intake/exhaust. The bigger the cam you run the higher the compression you can get away with due to cyl bleed off. Most people recomend baby 210 degree cams for use with boost but you wont make much power with them, cant even hear there in there. Hope that helps ya bud.
Posted on: 2009/5/24 5:10
Affordable Performance and Mechanical Repairs
0421 221 821
Adelaide
Re: cam grinds?
From Toowoomba, Qld
tighe cams in lowood are good also, they're very knowledgeable on A & L series stuff, and will make whatever you want.
Tighe Cams
Posted on: 2009/5/24 6:55
Re: cam grinds?
From Christchurch NZ
Don't go too wide with your lobe separation angle. The wider that angle is, the sooner the exhuast valve opens. If you've got it opening too soon, you lose too much power out the valve. 114' mite be okay of a nitrous or turbo engine, but I would stay around 112' for a supercharger. just my 2c.
Posted on: 2009/5/24 10:16
Forced Induction!
