EOI, for sale early A12 rally engine 100hp ATW stroked
From Perth
Hi i am selling my old rally engine, i has just been rebuilt after loosing oil pressure and turning no.4 main bearing. A14 Crank fully machined, new bearings and gaskets. fully cleaned and inspected. Here are some pics. (edited)
Posted on: 2009/6/21 14:26
Edited by rally1200 on 2009/6/21 23:10:03
Edited by rally1200 on 2009/6/21 23:10:52
Edited by rally1200 on 2009/6/22 13:37:59
Edited by rally1200 on 2009/6/22 13:39:32
Edited by rally1200 on 2009/6/22 13:40:11
Edited by rally1200 on 2009/6/22 13:40:41
Re: EOI, for sale early A12 rally engine 100hp ATW stroked
77mm stroke and 1mm undersize bearings?
Posted on: 2009/6/21 14:31
Edited by D on 2009/6/22 1:23:59
From perth airport
thing i saw this running at the autocross , sound'd better than any a series
Posted on: 2009/6/21 15:29
perth airport parking
Datsun 1200 ute A14
From Perth
More parts here. i will update the specs soon.
Posted on: 2009/6/22 12:21
From Cape Town, South Africa
A lot of drooling going on here.
Posted on: 2009/6/22 13:01
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
From Perth
Ok. engine specs
1398cc
A12 Early Block
A12 Rods & 76mm Mitsubishi pistons Flat top with valve reliefs - 18mm Pins
A14 Crank lightened and polished .020" undersized(77mm)
H891 Head ported and flow benched 37mm/30mm valves (results available)
Head fully serviced with 8 new valve guides and seats cut (guides left slightly longer/better life)
JTS Double Valve Spring shimmed up to 85lbs/seat 240lbs/nose with proper double valve spring retainers
Head heavily shaved for max compression 21cc chambers, with dimpled combustion chamber (intake turbulence)
1mm Head gasket & 1.5mm Head shim to drop compression down to 11:1
Set Used GX Head Bolts "13" grade
JTS 176c5 Cam Intake 49/71 Exhaust 79/41 with .4695 Lift
Multi-dowel Adjustable Timing gear
A12 Flywheel lightened to 6.6kg modified for 200mm Clutch/Pressure plate
JTS Headers Modified for 2,1/2" system
34mm Quad Throttle bodies with custom steel/ceramic coated intake
My plan is to finish the engine run it in and then dyno it.
Engine gives Very Good power from 3500 to 7500 and is setup for Pump 98 Fuel
working on a price for engine only or complete setup or make an offer.
Posted on: 2009/6/22 13:30
Edited by rally1200 on 2009/6/22 13:46:48
Edited by rally1200 on 2009/6/22 23:11:33
From South Africa, Bloemfontein
Hi rally1200
Sorry to hijack this thread, but I just want to know what throttle bodies are they?
Did they come from a motorcycle and if yes from what specific bike. Thanks. If I was closer I would have taken this engine as it is already very close to what I want out of mine. Hope the sale goes well.
Posted on: 2009/6/22 14:41
1977 Datsun 1200GX
From Perth
KAWASAKI GPZ 1100 Throttle Bodies.
Posted on: 2009/6/22 15:43
From Alice Springs
Hey, still for sale? what price are you chasing? PM me with one if you dont want to put it up. Cheers
Posted on: 2009/6/23 1:03
Daily: 1979
From Perth
OK Price.
I was thinking $2500 for the engine only (including flywheel)
or $3500 with Throttle bodies and Extractors
The Engine will be ready for sale in 2-3 weeks after finished assembly and dyno tuned.
Engine will NOT be sold with Dissy.
Posted on: 2009/6/23 10:09
