1k Rad/Thermo Fan Options
What Thermo fans are ppl running on their 1k Rads? ...sizes/brands/types?
I offered up a generic 10 inch but it doesn't quite fit, 8 inch seems a bit pointless unless i can get 2 side by side.
What other rad/fan combos pulled from non-Datsuns would fit well with as little mods as possible?
Posted on: 2009/7/10 14:59
Re: 1k Rad/Thermo Fan Options
From Perth WA
Why do you want to run a thermo fan? Most of the time the stock engine fan is fine!
I only run a thermo coz i run a Hyundai X3 radiator and there is no room for a engine fan. Its just some random fan a mate gave me that fitted infront of the rad.
Posted on: 2009/7/11 1:27
Chris...
cos theres bugger all room between the fan and the radiator! ...I guess its the way the gearbox/engine mounts have been made up. After putting the 5 speed in. the bottom of the fans arc was actually nicking the rad at times... so I thought putting in a thermofan would be easier than having to tackle the mounts.
Eh im about to be proved wrong again heh
Posted on: 2009/7/11 1:42
From Cape Town South Africa
I would say look at getting the motor back a bit because having that far forward is going to mess around with your handling alot. And then sort out the fan. Good luck
Posted on: 2009/7/11 7:29
Racing started the day the 2nd car was built!
Re: 1k engine too far forward?
Cheers Superbin, so I took some photos of the clearences and position of the motor.
heres where the fan just nicks the radiator at the bottom:
Heres the room I have left at the back...tho any further back Im going to hit the clutch fork on the firewall:
Maybe the 5speed gearbox mounts have pushed the lot too far forward?
The RHS engine mount:
Any discrepancies you guys could pick would be appreciated, could it be simply that the fan was too big?(thats kinda the answer im hoping for cos otherwise its a fair bit of work...but im well aware that the answer yr hoping for is often not what you get!)
Posted on: 2009/7/14 3:04
looks like its sitting a bit higher and forward than i would expect.
just use the thermo fans like you are getting other wise you would need bodgey clutch fan and water pump set up like i have and space it back.
at least no angles on the mounts making it look pushed forward, also gear box x member is round the right way,
might have to shave 3-4mm off the ends of each plastic fan blade to clear ;) and thats a free mod as a temperary measure till you get it sorted past rego
Posted on: 2009/7/14 3:54
Ive often wondered if anyone has found a company that is willing to make new waterpumps
for the A series to reduce the depth much like on modern engines. This would provide
extra room for the radiator, fans and intercoolers.
Posted on: 2009/7/14 4:04
From Geelong, Vic
how much room do you have between the sump and the crossmember, coz with miks 1200 the engine was too high and a little further back so the clutch fork was hitting the tunnel
so if you can go down a little you might be then able to go back also
Posted on: 2009/7/14 4:43
and the lower the fan, the more it might hit, but would be ok further back.
yeah mines so bad that the previous woner cut a hole in the tunnel, damn him, anothe reason to replace it ;)
Posted on: 2009/7/14 6:20
From Melbourne Vic
get an original a10 metal fan, that should give you plenty of room. thats what i have on my a14 in my thou
Posted on: 2009/7/14 8:12
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
