H145 Bits Needed
From Cambria, California
Need some H145 pieces that are NLA Nissan USA:
* Pinion nuts (3ea.)
* Pinion seals (3ea.)
* Crush sleeves (3ea.)
* Axle bearing retainers (2ea.)
THANKS!
Posted on: 2009/8/10 18:11
Re: H145 Bits Needed
From Oberon NSW {Bathurst}
I'll have a look in the shed, do you have numbers.
Posted on: 2009/8/10 21:00
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
I'll check online & with the local Nissan dealer for part numbers and post them here.
Posted on: 2009/8/11 1:27
Here's PNs I was able to find:
* 43255-18000 Axle bearing retainer (need 2)
* 43215-H5000 Axle wheel bearing (need 2)
* 38189-18000 Pinion seal (need 3)
* 38165-H1001 Pinion gear crush sleeve (need 3)
* 38216-H1000 Pinion yoke nut (need 3)
Thanks!
Posted on: 2009/8/11 22:41
Edited by OGREInc on 2009/8/12 1:02:29
You can get the axle bearings from any bearing supply company (don't ask for a Nissan or car bearing, ask for it by number, e.g. NSK B32-3CC5) Axle wheel bearing Part Numbers
And edp just bought bearing retainers last week.
Posted on: 2009/8/12 6:28
From Brisbane, Australia
Add a shim and your crush sleeves are good to go again. . .
Posted on: 2009/8/13 6:47
Cable_Tie, are you saying the crush sleeve may be reused as long as you add a spacer to crush it bit more? Makes sense I guess.
Posted on: 2009/8/13 6:55
Interesting, re: crush sleeve shims. Sourced from? The gent doing the refurb on my differential is dubious, but as I told him "What's a mother to do if the NOS parts aren't available?" I DID find a set of interchange bearings for the wheel bearings, so I'm good there. Still need the wheel bearing retainers.
Thanks all!
Posted on: 2009/8/14 18:06
The 'shim' is just a washer...
Posted on: 2009/8/14 23:00
It's not a washer, just a thin shim of about 10 thou or so. It's just enough so that the sleeve can be re crushed to archive preload.
Posted on: 2009/8/16 13:45
