(1) 2 3 4 ... 9 »
perthute's 1200 4 door inj turbo A14
From perth airport
anyone want/buy this ? has ill use my O O O dash
new O O O dash to go in heat rap for manifoild boost gauge n a gay streeing wheel
tacko :)
2.5 zorst all the way from turbo to tip
ca silvia seats n new door trims
wat rims are these ?
just got the car, it was runing this set up untill it dropped a ring so the last owner swap motors and did a few things hear n there , but its been 8 years since last startup so ...
i flushed the rad. new oils/filters new leads new plugs 30ml of oil in each spark plug hole to try n lube it up a bit . wash'd fuel tank out and new fuel 98 went in new batt ect ect
anyway waiting on some efi fuel hose befor i can start up
Posted on: 2009/9/27 23:10
perth airport parking
Datsun 1200 ute A14
Re: perthute's 1200 4 door inj turbo A14
From Perth
They look like performance strikers I've got a set on my ute
Posted on: 2009/9/27 23:28
From perth airport
forgot to say its been mod plated or permited wateva your sate calls it :) so should be easy reago if it runs sweet :)
Datsun 1200 ute A14
From Coondle, WA Australia
its a pity that the intake manifold is standard.. could have saved me some hassle. Oh well its only a 1200 anyways....
Posted on: 2009/9/28 2:10
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From perth airport
only a 1200 lol welcome 2 1200.COM :p
that would finish the set up perfectly tho :) bummer
Posted on: 2009/9/28 3:11
Datsun 1200 ute A14
From Perth
We saw this car on the shed cruise
Its got that wierd injection setup on it
I don't think that will last long on there
Posted on: 2009/9/28 5:07
From perth airport
whys that ? it was running fine before cant see why i would change somthing that works fine
Posted on: 2009/9/28 6:11
Datsun 1200 ute A14
From Armidale N.S.W
Your the envy of many Jordy, For $1000 bucks its the score of the year i reckon.
Posted on: 2009/9/28 6:38
73 1200 wagon SOLD
From perth airport
yer n had some good spares :) tomorro it should be running might get a you tube clip :)
Posted on: 2009/9/28 8:31
Datsun 1200 ute A14
From Albany, Perth Australia
and its now runing on 12's hehehe
Posted on: 2009/9/28 8:53
1200 Smerf Mobile
(1) 2 3 4 ... 9 »
