« 1 (2)
Re: A12GX Head - Su's - Lightened Flywheel
From Cape Town South Africa
Dude its a datsun what did you expect! Lol very well done
Posted on: 2009/9/29 10:31
Racing started the day the 2nd car was built!
From NZ
Regarding the dyno printout: why are there two different sets of power and torque readings (and at different - presumably 'peak' - rpms)?
Posted on: 2009/9/29 10:49
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
From Cape Town, South Africa
It was two runs, the last one we adjusted the timing to 6.5deg.
Posted on: 2009/9/29 11:06
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
From South Africa, Bloemfontein
Am I reading the chart right?
80Kw and 128Nm. Is this at the wheels or flywheel.
Mine made a pathetic 37Kw at the wheels with a stuffed exhaust and badly tuned Su's that caused little puffs of black smoke at high rpm.
Posted on: 2009/9/29 13:13
1977 Datsun 1200GX
From South-Africa,Pretoria
Hey, i used the mause manifold with my 36/36 DCD7 Weber, Running Demon RST intakes for my twin 40DCOE's, What makes them different are, they arnt joined in the middle. Also using A custom 4-1 branch built by Speed Spot PTA. ^_^
Posted on: 2009/9/30 0:35
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
Yeah my old setup(276cam and 36dcd7 Weber) made 60kw atw on speed spots dyno. 80 kw on the wheels ? Thats gooood :D
Posted on: 2009/9/30 0:38
From ACT
Nice work thats around double my A14 w 36/36 DCD 4-1 branch and stock everything else (44.7rwkw), makes me look fwd to rebuilding that engine and making some "serious" powa!!!!
Posted on: 2009/9/30 1:38
Now riding dirtbikes:
Lots of A series Datto stuff for sale
« 1 (2)
