key,s locked in sunny
From Brisbane Qld
Hay i done a silly thing i have locked the
sunny with the only set of key,s i have for it inside
can any body tell how to get it open with out
calling RACQ
Posted on: 2009/10/31 6:50
Re: key,s locked in sunny
From Perth WA
brick thru the window... its only a Sunny!
Get a coat hanger, make a hook in it and go fishing inbetween the window and door skin
Posted on: 2009/10/31 7:10
Chris...
I've succesfully done the coat hanger thing, try to hook the interior door handle
Posted on: 2009/10/31 7:14
From south coast nsw
if u cant break in with a coathanger or packing tape find out wat window is cheapest to replace then enjoy smashing a window on your own car.or try other datsun keys if u can
Posted on: 2009/10/31 7:15
From Christchurch NZ
get a screw driver, and GENTLY lever the door frame out from body. get a loop of blue packing tape and feed it through the gap. Slide it down and hook it over the lock knob. Pull it tight and slide it up. and bigo you're home and hosed.
I used to have a sunny with no door key. (I just used to never lock it) but sometimes I'd lock it by mistake, and have to use this method. I could get into it in under 30 seconds with ease.
Posted on: 2009/10/31 21:24
Forced Induction!
From Brisbane Qld
Thank,s for all your help guy,s another
datsun nut i know gave a hand and got it
open with a coat hanger.
Posted on: 2009/11/2 14:59
From illawarra, nsw australia
Im hopeless for this so i always have a door key in my wallet, just an idea for the future :)
Posted on: 2009/11/2 19:55
From Townsville, Qld
racq guy reefed the doorframe to do the A14force method because we all have those superior gutter channels on our car >_<
Posted on: 2009/11/3 0:14
The pro lock out guys have a flat plastic thing they sldie in, and then inflate to force the door gap open without scrathing the paint.
Posted on: 2009/11/3 6:35
Forced Induction!
From Taupo New Zealand
I've locked the keys in my sunny a couple of times. The packing strap worked a treat. I locked the keys in a commodore I had once, couldn't get in had to call the locksmith for that one
Posted on: 2009/11/3 7:49
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
