« 1 ... 4 5 6 (7) 8 9 10 ... 20 »
Re: Bailz's 1200 Ute...
From Perth WA AUS
Hopefully I'll be done by xmas aswell.
Posted on: 2009/11/1 13:07
Datsun 1200 2Dr sedan.
From Albany, Perth Australia
i can only hope mine will be done...
Posted on: 2009/11/1 13:24
1200 Smerf Mobile
From Perth WA AUS
Finger pulling time then Brett! hehe.
Posted on: 2009/11/1 13:30
i will upload a few pics if i get time tonight
Posted on: 2009/11/2 13:15
From Perth WA AUS
Pics or ban!
Posted on: 2009/11/3 8:13
ca is sittin in... need the different dump pipe..
Posted on: 2009/11/7 15:17
well as my luck would have it, the ca is in now. just need to mount up the gearbox cross member... took a but of muckin around to get the ca in... dropped it in with noteven one hit with the hammer on the tunnel :) maybe i am just patient :)
well all is good, gunna mount up the crossmember tomorrow... chuck the tailshaft in... and then mount the alternator, throw the rad support with intercooler and rad in place. mount up thermo fans and wire them up :) then go drink beer :)
Posted on: 2009/11/14 13:22
From Freo
good work Bailz.. :)
Posted on: 2009/11/14 15:19
A15 PSI Project Motor
'72 CB750k,
From Mandurah, Western Australia
Sounds good bailz
Had a look at Pintarra. It uses a 2 piece tail shaft, which is only about 50 mm in diameter. Did not pull it out of the box to see what yoke it had on it, but in my opinion you would be better with a 180B or Stanza tailshaft.
If you could confirm if it fitted you could get one this car for $20 I reckon. He was a reasonable guy. But I did not want to dump any more oil on his drive than I had to.
Posted on: 2009/11/15 2:33
old_school's 1200 coupe
From Griffith
hey bailz,
how did you put the ca in without smashing the tunnel out?, did you put the motor and gearbox as one ? what crossmember are you using?
reason i ask this is i am going through this process rite now
Posted on: 2009/11/15 4:30
