Datsun 1000 shocks?
From Stirling, South Australia
I'm having a little dificulty in finding shocks for my wagon and wondered if anyone has some part numbers of suitable alternative shocks for both front and rear. I can get original nissan shocks but the cost is a little prohibitive.
Posted on: 2003/10/15 11:46
LIFE'S TOO SHORT TO DRINK INSTANT COFFEE!
Re: Datsun 1000 shocks?
Quite a regular
From melbourne
I have heard that the front shockers from an LJ torana will bolt straight on to the front of a 1000,never tried it myself but could be worth a look
Al.
Posted on: 2003/10/15 12:04
From sutho shire
sorry 2 get of the subject but has anyone changed the front leaf sprung end of a 1000?
im interested as im going 2 change the front end on my ute..
Posted on: 2003/10/15 13:11
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Perth WA
i want to know too.... surely someone can shed some light on it.
What about you fellas running the racing 1000s -steve, theres another 1 too, whats the go with susp upgrades?
Posted on: 2003/10/15 13:58
From Perth
I can't remember the rear ones but I know they are still available from Gabriel.
For the front I used LJ gas ones. They don't fit straight in.
What I did was press out the bottom pin from the torry shock . I made a copy of the datto pin in solid stainless as its usually hollow and bends when using gas shocks.
I used nolothane bushes which I had to modify to fit into the upper and lower ends. The upper eyelet required thinning to fit onto the existing spiggot. I pressed the bushes into place and glued them so they wouldn't come loose.
I can take pics of these if need be.
I will be changing the front to coil overs at a later stage but haven't done it yet. The rear is 1600IRS but also not totally completed yet......most of its in though.
The racecar is full tube chassis and runs torana LJ stubs on fabricated arms with coil overs. The rear is all custom using Jag coilovers......so the racecar suspension doesn't relate at all to a roadcar
Posted on: 2003/10/15 14:05
1000collector for my 1000 wagon Pedders supplied my with their listed replacement shocks with part numbers;
front = 3029
rear = 8024
Posted on: 2003/10/15 14:09
From Perth, West Aussie
yea I got a set of pedders for mine
I have the book 'build a sports car for 250 pounds' (lotus 7 replica) and it wouldnt be too hard to fabricate the multi link kind of suspension with coil over shocks they use.
Posted on: 2003/10/15 18:25
