1200 Hydraulic clutches
From Sid-knee
I haven't started anything but i am thinking about my clutch and my CA conversion. Has anyone ever put a pedal box out of a 180b, or any other booster and hydraulic clutch equipped datsun, into their 1200? I have a pedal box, that i think is out of a 1600, that is pretty big and i don't think i can modify it to fit.
Also, can some people who have done the hydraulic clutch conversion take some pics of their mods and post 'em.
I can't stop thinking about getting in and working on my ute but until uni is done for the year i have no time (but still manage to read sh*t on this site for hours while "doing uni work" on the computer).
Posted on: 2003/10/16 3:50
_____________________________________________
1999 Subaru Outback - Not exactly a Datto...
Re: 1200 Hydraulic clutches
From Adelaide
what you can do is a buy a cluth master im not sure what type it is i bought mine of maddat in adelaide. And all you do is line up where you will mount it on the firewall in rererance to the clutch pedal use a hole saw to make your hole then remove your pedal drill a hole in that below the pivot for the fork of the master to attach to and re assembly maddat even supplied then braided line to the slave hope that quick run down mad sence and helped
Posted on: 2003/10/16 4:20
From Sid-knee
i have done a quick check and the clearance between the edge of my 120y booster and where i'd need to install the clutch master (out the S13 1/2 cut) wouldn't work like that...
Plus with a pedal box from another car (i'd expect) the booster and masters, etc would bolt up to (stronger) plates attached to the pedal box rather than just the fire wall???
thanks matsfatdat.
Posted on: 2003/10/16 4:44
From sutho shire
hay jack i have a hydrulic clutch set up and croos member for sale 550$ never used if u want it from maddat especially for ca18det i have jsut used one set on my ute and workes perfect i had ordered 2 but no need for one set.. ( still brand new in a box with braided line.. ect
if u are interested pm me and will organise posting..
cheers andrew..
Posted on: 2003/10/16 6:33
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
From Sydney, Australia
The 120Y Booster mod is a step backwards.
It makes the hydraulic clutch conversion very difficult.
Chris
Posted on: 2003/10/16 7:21
Quite a regular
From sunny QLd
what booster should u run then? with a ca18det motor? what will fit..
Posted on: 2003/10/17 3:37
From Adelaide
Sorry jack i didnt realise you were running a booster i can see how you would have very little room it does work fine with out a booster fitted
Posted on: 2003/10/17 3:56
From Warwick, QLD
Hey Jack check this out
In Cabin Clutch Master
It solved my prob with clearance of booster and intake plenum
Cheers
Damo
Posted on: 2003/10/17 13:17
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
