« 1 2 3 4 (5) 6 7 8 ... 10 »
Re: Lightweight CA18 - need your input from CA18 freaks
From Geelong, Vic
haha D its funny you should put a pic of those rods up, i was at my engine builder/machiner today getting some prices on CA parts are he was carrying a box with those rods in them
i was very impressed that they were stock rods, will compare my SPOOL ones to them if hes still got the engine apart when my rods arrive
Posted on: 2009/12/11 8:37
must be an engine builders industry secret thingy that bmw rods are
the creme of the crop in engine hybrids.
So you spooling out for the H beams? what pistons you going to run?
Ive seen some bmw aftermarket forged pistons weighing round 400 grams
somewhere, I think they where 27.5mm in comp height.
Nick forgot to answer the 8v head qs in your PM
The 8v heads are all the same except early ones are not twin spark,
camshaft grinds are different and early ones are solid lifters.
The 8v looks like an early dodge hemi and late semi hemi twin plug hybrid.
jpg  ca20head.jpg (31.34 KB)
737_4b22355984d67.jpg 469X215 px
Posted on: 2009/12/11 11:51
From Christchurch NZ
That is a good looking chamber. And only having the two valves, there is probably a whisker more squish than the 4 valve chamber? best thing with the dirty old hemi chambers is the absence of shrouding.
Posted on: 2009/12/14 5:47
Forced Induction!
by 1000Coupe on 2009/12/11 2:26:42
whats beutiful about it? Mitsubishi 6G family engines with 4 bolt mains rods from factory would be more a thing of beuaty imo.
lol u love ure bitsaremissings dont ya!
Posted on: 2009/12/14 6:42
From Geelong, Vic
will buy the H beams as soon as i figure out what i should leave the guy as a referance
gotta measure my block before i order pistons, going wiseco 20 thou over forgies most likely, ACL ones come in at 322 grams so im guessing mine should be about that
and just ordered some new timing belt sprockets for the crank as the one on my engine is stuck on and the one on my spare engine didnt come off even after destroying everything around it to get leverage
cost $26US each compared to the $98 the local nissan dealer wanted
Posted on: 2009/12/14 12:28
Nick where was that 26usd price from ebay?
Also are you going with the same rod length and piston height as
they are off the shelf items or going custom?
Posted on: 2009/12/14 23:37
From Geelong, Vic
it was from http://www.nissan-auto-parts-dealer.com/ gotta now figure out shipping price as it was supposed to be $20...then they said it would be $99 which is bullshit
and yeah just stock rod length and piston specs
Posted on: 2009/12/15 5:16
I had payed for an alloy crank pulley a while back for a suzuki engine
and later the post was going to be $70USD, lucky I used paypal and got
my money back as the bastards would not nudge for a less than 1 lbs part.
Just found some billet camshafts that are very cheap for turbo SOHC setups and also NA.
http://www.importperformanceparts.net ... ts/ippwebcam-nissan1.html
IPP/Web-Cam Performance Cam Kits (Stage 1 & Turbo)
Nissan CA20S Stanza '82-83, CA20E 200SX/Stanza '84-86 SOHC (Stage 1)
Nissan CA18ET 200SX Turbo '84-86 SOHC (Turbo)
IPP, through an exclusive distributorship with Web-Cam (one of the premier cam manufacturers in the USA),
has designed a line of solid billet cams for Nissan's. These are new cams with no cam cores required!
Stage #1 Specs:
Cam Lift: 311 INT, 311 EXH
INT & EXH Duration @ .020 is 260
Lobe Centers: 110
Description: Good idle for daily use. Improved low to mid range torque. Use stock springs and retainers. Stock compression OK, but will work better with increased compression.
Part # (Stage 1): IPPWEB-460 Price: $179
Cam Kit Stage #2 (Turbo)
Stage #2 Turbo Specs:
Cam Lift: 317
INT & EXH Duration @ .020 is 255 INT, 255 EXH
Lobe Centers: 110
Description: Designed specifically for Turbo or Supercharger Applications.
Part # (Stage 2): IPPWEB-40EX Price: $179
Edit: too mild for quad carbs and my needs
Would prefer at least 10mm lift and more duration
arp head bolts for the 8v
http://www.summitracing.com/parts/ARP ... 2D202%2D4702&autoview=sku
Posted on: 2009/12/15 5:46
Edited by D on 2009/12/17 9:10:11
Edited by D on 2009/12/20 22:23:47
Edited by D on 2011/3/6 0:01:23
Just wondering if there are any of the front wheel drive EXAs
with the ca18de that dont have the crank girdle?
It seems Sylvia ones all have the girdle and I took it
off to check its weight and its has to weigh maybe 2kg.
I was surprised how soft the main bolts are from factory
and also how strong the webbing is inside these blocks.
I doubt this block needs the girdle even over 400hp.
Its similar to the toyota 2tc engine which in puerto rico
are making over 800hp with.
Also Ill be on the lookout for a simple crank, alternator,
water pump single pulley kit but its seems the crank one
is only available separately.
Also anyone know of an external filter kit as the factory
ca18de filter is for like a lawn mower very poor.
eg. which size????
http://www.summitracing.com/parts/PRM-10695/?image=large
Posted on: 2009/12/16 22:33
Edited by D on 2009/12/17 9:09:40
Edited by D on 2009/12/17 12:18:53
Edited by D on 2009/12/17 12:27:59
From Geelong, Vic
plenty of remote filter kits out there that would do the job and that use larger(ford i think) filters
found a relocator with cooler and thermostat a while ago to suit nissans, forget where though
Posted on: 2009/12/19 5:12
