1200 front springs
From gold coast
hey guys i donno if anyone has been looking for stiffer springs cause i just found front springs out of a nissan navara 4wd
they fit pretty good but they are sooooo stiff it doesnt really move but i was just wondering if anyone has found some
other spring that fit standard struts ive been on the look out and rear cx7 springs are the same size i just dont know if they will be stiff enough
Posted on: 2009/12/19 2:43
Re: 1200 front springs
From perth airport
would be good for a cheap drift setup
Posted on: 2009/12/19 2:50
perth airport parking
Datsun 1200 ute A14
From Geelong, Vic
200b or bluebird rear springs cut down work nicely, gemini front springs i think also work
Posted on: 2009/12/19 5:07
From Melbourne, Aus
I have fitted 240z springs on the front of mine. They work quite well.
Posted on: 2009/12/19 20:52
From Christchurch NZ
I've heard that avenger wagon rear coils have a really good spring rate for 1200's.
Posted on: 2009/12/20 0:05
Forced Induction!
From gold coast
hmm theres a few odd ones there i guess i wouldnt mind going into pedders or something and see if they can give me spring rates
Posted on: 2009/12/20 8:32
gemini fronts - you can pick the early (I think TX from memory???) ones - the first gen gemini are single rate (my preference) or all later RTS models are progressive rate springs. They are a nice increase in spring rate (esp after a coil or two is cut off to get the ride height you want, i'm conservative there), and cost about $30 from a wrecker. I got mine from a bloke off the ozgemini.com website - just put a wanted add there, and hey presto.
Compare that to the ordeal I had ordering the 'right' springs from a local spring vendor, to find they were more than an inch too short to be captive, to take them back to hear 'that's not our problem, they are ok like that'. I then went with another option (after contacting King springs head office) - the rear springs off a hyundai excel or something - KHRL-115 . They could _probably_ be made to work for 90% of people out there, but I wanted a slightly different ride height, and didn't want to stuff about any further with them, (they would be captive however even with 1 coil off the 'heavy' end or 2 off the closer 'soft' end - they are progressive rate).
If anyone wants the khrl-115 springs, free to good home, still wrapped in shrink wrap. I'm in melbourne, would send interstate for cost of postage (probably $25-30) if sopmeone wanted to experiment with them, but honestly I'd still suggest the gemini springs are 'the go'.
Posted on: 2009/12/20 23:42
John McKenzie
From gold coast
thanks for that mate i guess ill try that out see how we go with that but i really want the rear stiffer to but i think im just gonna have to get a new rear spring pack
Posted on: 2009/12/27 7:33
