« 1 2 (3) 4 »
Re: CA18DET into 1200 general questions
From SE Melbourne
In case anyone is wondering - this is the knock sensor (top plug in the photo with white/grey wire coming out)
Posted on: 2009/12/21 1:53
Mildman, Datsunless
i think we should make a sticky in here for ca18det's??
here a site for nissan airflow meter wiring connections :)
http://paulr33.skylinesaustralia.com/ ... airflow-meter-wiring.html
Posted on: 2009/12/21 2:21
From Melbourne, Australia
MORE QUESTIONS:
mucking around with mounting the motor in over the last couple of days
the engine is sitting on the cross member with 38mm high rubber mounts and only just clearing with about 10mm spacing added. What size are the rubber mounts other people are using? (crossmember is basically a copy of a maddat one)
also the sway bar looks to have no hope of mounting back up, i thought people were using the stock sway bar/120y sway bar with CA18Det?
Posted on: 2010/1/7 10:50
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Mandurah, Western Australia
I had custom swaybar made as 120y bar would not fit.
Should also mention I have not used Maddat components.
Posted on: 2010/1/7 12:38
Edited by old_school on 2010/1/7 13:42:34
its obviously not a maddat replica... my one fits mint... how far off the firewall is your engine?
have u removed the sway bar? mine is all linked up perfect... heaps of clearance... i am not being a bad customer but maddat gear is not really trialed on a car by the looks of the stuff i have got off them, u ask for a better price and they make comments like "do you think we are a charity case?" after u explain that the item u have which is made by them is a poor fit.
Posted on: 2010/1/7 13:07
From Perth Austarlia
"no ambient temp or manifold temp, only water temp"
Not a very good idea. Most computers uses air temp to calculate the correct amount of fuel. So on a cold day it will add fuel and on a hot day it removes fuel. I can't talk specifically about the ca18, but with no air temp sensor, wouldn't the computer go into limp mode?
Posted on: 2010/1/7 14:12
nah, pretty sure... the ca doesnt go into limp mode when u dont have ambient temp connected...
it puts an artificial figure in from the water temp input into the ecu... as it says in the 895 pages of usuer manual ;) i think i have seen most of them lol....
correct me if i am wrong?
Posted on: 2010/1/7 23:46
From brisbane
I had a custom swaybar made as the standard 1200 bar just touched the front of the sump. Kev Rowley did my conversion.
Posted on: 2010/1/8 0:02
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
my enegine is hard against the firewall.. not much room to spare
Posted on: 2010/1/8 0:19
From mandurah
hey bailz my engineer said that the engine has to be aleast 1 inch away from the fire wall
Posted on: 2010/1/8 4:18
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
« 1 2 (3) 4 »
