engine swap question
Quite a regular
From Houston,Texas. USA
Hello there, I'm thinking on getting a c18 twim cam engine on my 1200 coupe (nissan pulsar in US), my question is i don't want to go to all the trouble to convert and adapt the fuel
injection and all the electronics(and a big hole in my packet and probably a divorce),can i remove all the fuel injection and all the electronics associated with it and install a
manifold and maybe a set of weber carburators. Will this work with this engine? I will apreciate any coments or ideas. thanks guys
Posted on: 2001/4/25 2:34
Re: engine swap question
From Invercargill, New Zealand
Yeb you can run that motor without injection but why would you if your goal is saving money? Presuming that you are getting a complete rear drive motor, trans and computer - you won't
really have too many dramas with the CA18DE. Just a bit of rewiring, engine/gearbox mounts, tunnel massage, radiator. You have to do these things any way but non-standard you're going
to have to find, additionally, a manifold (probably custom made) and 2x Weber 45's. What US Nissan has the rear drive CA 18?
Posted on: 2001/4/25 11:33
From Sydney, Australia
What's more important..your datsun or your marraige...just kidding . I too suggest using the computer, as the carburation option may be more costly and time consuming. I'm guessing
it's the time-consuming part that has the potential to cause harm to the aforementioned..
The Computer install is almost dead easy, especially if you have a full loom. I can scan and send you wiring diags that will help. And it will run quite smoothly, it's not 100% because
you won't have a speed sensor, which in my experience makes it play up a little. But the associated symptoms with that are fully bareable.
Just think of the ease of turning the key and the engine starting in less than a second..no more choke..less swearing..it's got to be good for your marraige. Definitely go for engine/
loom/computer option. Otherwise you are heading into unchartered waters.
Chris.
ps. I've installed 2x CA18's 1xDE and 1xDET.
Posted on: 2001/4/25 11:51
Quijoteus if you only have CA18 motors in pulsars in the U.S I would not attempt to put it in a 1200.This is because its a fwd engine and you will have alot of
trouble with manifolds and gearboxes. You did say that the motor was coming from a pulsar.
Posted on: 2001/4/26 12:32
Tony I remember seeing a Pulsar web site and the late model Pulsar they had a picture of was in fact our NX Coupe. Was it front or
rear wheel drive.
Posted on: 2001/4/26 6:30
