Anyone ever seen a 60 series box for a CA?
In interest of weight reduction Im interested to see if anyone
knows of a way to use a 4 or 5 speed 60 series box from either
bluebird, stanza, c20 or vanette to power a Ca18?
I dont think bellhousings where ever made for the ca16/18 to
run on a 60 series but maybe some japanese cars did?
The last alternative is to cut and shut a 60 series with a stumpy.
The reason is my b10 is just under 600kg and the ca18e Im building
will be 10kg heavier than an a15 so 20kg can be saved using a
60 series over the stumpy.
60a weighs in at 25kg, Stumpy/63a at 45kg from what I remember.
I can knife edge the ca18de crank to reduce 4kg but thats an expensive
path to save kgs. Im 65-67kg but cant go any further down as my frame
will not suit any less in physical training or I wont be competitive.
Weight is the enemy except in Sumo wrestling :)
Posted on: 2010/2/9 3:01
Re: Anyone ever seen a 60 series box for a CA?
60-series is not strong enough for a CA18, not even carbureted model. In any case they were only fitted to A14 & A15, no others.
60-series 5-spd: 32 kgs
CA18DET 5-speed: 43 kgs
Posted on: 2010/2/9 3:16
From Christchurch NZ
You need at least a 63 series gearbox.
I want to go the other way. I'd like to fit my 63a bellhousing to a stumpy 71 gearbox. But AFAIK they wont be compatable. (plus a bigger stronger box wont do much to prolong the life of synchro's that get abused.
Posted on: 2010/2/9 6:24
Forced Induction!
You need SynchroRev Match. That will protect your syncros. Only available from Nissan.
Posted on: 2010/2/9 7:01
From Sydney, Australia
Has any one just removed some gears and shafts to reduce box weight?
I used drive my ca18de around on 1st,2nd,4th gears.
Cut down flywheel proportional to vehicle weightloss s13 to b10.
Just some thoughts
Posted on: 2010/2/9 7:55
please elaborate DD? (sorry for jacking your thread D)
Posted on: 2010/2/9 8:03
Forced Induction!
Search for it. It is most amazing and only available on the 370Z.
Posted on: 2010/2/9 8:16
Due to the weight of the b10 the ca18 wont ruin a 60a if driven properly.
60a can take the abuse of a turbo a15 so a mild ca18 soch setup will take
the abuse in such a light car.
Posted on: 2010/2/9 13:18
You likely could graft a CA bellhousing onto a 60 series box. But it would require a decent workshop, and a tig welder who knows what he's doing.
Posted on: 2010/2/11 4:20
Forced Induction!
From Melbourne, Oz
Make an A series stumpy while your at it for a cash rebate.
Posted on: 2010/2/11 5:24
"I hav achieved wood"
