Browsing this Thread:
1 Anonymous Users
Bluebird H165 disc rear, will it fit Stanza H165 diff? |
Hi All
Not a 1200 (although I am building about 3 1000'S!) Does anyone know if the disc brake rear from a H165 bluebird will fit a H165 Stanza? I would assume so but thought someone might know for sure...?
Posted on: 2010/2/10 14:24
Re: Bluebird H165 disc rear, will it fit Stanza H165 diff? |
From hastings,vic
i no bluebird/trx disc setup will bolt to 1200 ute 165 housing so would presume it will fit stanza
Posted on: 2010/2/10 21:22
taking up room at home 3 now 2 1200 sedans,3 now 2 1200 coupes,3 now 2 1200 utes 1 1000 wagon,2 s13 silvia's,tranzit tray hzj75 cruzer tray(for sale) and allways changing
From Darwin NT
yep i can vouch for that as i have a ute diff sitting at home with the bluey disc brakes
Posted on: 2010/2/10 22:15
-68 1000 wagon long term project sleeper style with heavily worked a series -evrything in storage... bugger current project 4x4 patrol...
Registered Users Contentmaster Usermaster
Any H165 diff center will bolt into H165 any rear axle assembly. But the early ones had three different side gears, which can be swapped to match the axles.
Posted on: 2010/2/11 3:36
From Christchurch NZ
Aren't those bluey's drum over disc? Sounds awful heavy to me! U13 rear disc can be adapted without too much diffculty.
Posted on: 2010/2/11 4:16
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
From Nations Capital, Australia
Is the bluebird TRX rear disc brake swap hard to do?
Posted on: 2010/2/11 10:59
From Geelong, Vic
about as hard as changing the rear wheel bearings
Posted on: 2010/2/11 11:14
From hastings,vic
and hand brake hooks up like std
Posted on: 2010/2/11 11:18
So basically just unbolt it off the TRX diff, and bolt on the Stanza diff!???
Its always the way... Id been looking around for a H165 Stanza Diff for a while, (hard to find) then found one on ozdat in QLD (Im in ADL!!) Any way I brought and its getting freighted down... Then my mate from a wrecking yard pulls up in my drive and says hes just had 2 cars with them fitted come in, so he brought them around and dropped them off!! Never rains it poors!
Posted on: 2010/2/11 11:35
Nice.....I like easy conversions!
Posted on: 2010/2/11 11:48
