« 1 2 3 4 (5) 6 7 »
Re: datto ute handling (or lack of)
From Melbourne AUS
yeah i kinda figured that, but the question is where?
Posted on: 2010/2/16 6:19
1973 B110 A12
From Melbourne, Australia
not ebay, they are crap
wouldnt mind giving a hill climb a go, but have a rally on the 6th
if $55 is considered cheap... join one of the rally clubs, they are cheaper and cams affiliated just the same, i think $30
Posted on: 2010/2/16 6:33
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Adelaide, Australia
This is where i got mine...
http://www.importbitz.com/koni.htm
You just have to clear off the old spring seat, linish the strut tube, slide on and weld around. I think there are cheaper around but you want steel weld on ones not grub screw type. Datsport etc. only seem to sell them to suit the larger tube struts.
Posted on: 2010/2/16 6:53
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Albury
You could buy a few sets of normal springs and get it right for the same expense of going to coilovers
Posted on: 2010/2/16 7:02
From Melbourne Vic
While coilovers are good to adjust height and spring rates are more easily change if you were to go to that effort you've gotta shorten those struts!
also nothing wrong with the grub screw type, my 200kw 1600 with big fat 225 50 16 race rubber has done plenty a track day and ridden a few ripple strips with no problem. Thats just what the steel sleeve sellers tell you haha
might try head down for a look on the 7th
Posted on: 2010/2/16 8:13
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Gold Coast, Australia
http://www.otomoto.com.au/HDSystems/sleevekits.htm
cheap and very good quality with everything you need. Koni shocks are $303each cost and retail for about $380 each so screw them down for price. Cusco adjustable tops for b110 cost me $365.
Posted on: 2010/2/16 10:04
Edited by 2QK4U on 2011/1/23 12:26:33
the otomot ones look ok, and come with helper springs and the spanners too.
Posted on: 2010/2/16 10:09
From Adelaide
Thicker front swaybar (i use a adjustable 22mm), Shorten front struts and run a fermer insert, use smaller rear bump stops or cut them down, good adjustable rear shocks, 250lb springs on the front and reset rears with a extra full leaf and remove load spring. Coilovers on the front if the budget allows (we now do coilover kits for 120y/1200 45mm strut tubes)
This is what mine sits like on hard cornering.
http://datsun1200.com/uploads/photos/20556.jpg
Posted on: 2010/2/16 10:56
From Geelong, Vic
1200RC whats wrong with ebay coilovers? never had a problem with mine
would rather pay $130 for a set of 4 than say $200-300 a pair for the same sorta thing, alloy vs alloy that is
Posted on: 2010/2/17 11:42
From South Africa, Bloemfontein
sssute's pic looks good to me. Try that setup.
Posted on: 2010/2/17 12:11
1977 Datsun 1200GX
« 1 2 3 4 (5) 6 7 »
