« 1 ... 3 4 5 (6) 7 8 9 ... 15 »
Re: GUESS THE H.P........... BIG PRIZES FOR CLOSEST GUESS!!
From Ballarat Victoria
I dropped the block off to be honed and the head for a valve grind.
I also found some new heavier progressive rate valve springs today they are 240lb at full lift. Considering the stardard units are 100lb it should be plenty for 8000rpm and plenty of boost. Progresive rate is a newish technology apparently.
Start making turbo manifold next.
Posted on: 2010/2/15 9:59
just want my $100 or dyno tune ;)
Posted on: 2010/2/15 10:43
From Melbourne, Oz
are you going to use that hand formed plenum?
Come to think of it I think it will be the wrong side? Im sure it will be verry neet regardles!
Posted on: 2010/2/15 10:50
"I hav achieved wood"
From Sydney Australia
147 rwhp
Posted on: 2010/2/15 11:17
Block is honed, the head is reco`d. going together sunday. I was going to buy a good head gasket from Dundee1000 but decided to use a cheapy. Budgets already blown, lets hope the head gaskets not next!
$50-Second hand engine.
$70-Full gasket set.
$60-cast rings.
$80-Hone engine.
$200- Head reco.
$165-ARP head studs
$625... More than i wanted to spend!
I just want the rings and the valves to seal.
Im not going to get too fussed with looks(manifolds etc). As long as i can get the air and fuel into it i`ll be happy.
The engine won`t be in there for long.
Just remember with your guesses, its a stock engine! except for valve springs and head studs.
Im loving the optimism tho!
Posted on: 2010/2/19 12:41
VIC DYNO HIRE
Simon have you checked how much the the cometic gaskets are?
If I win I want your manifolds discounted the winners purse
when youre done with them :)
Posted on: 2010/2/19 13:01
About $230 USD + shipping. I figured a blown head gasket might save the bottom end.
Standard should be fine if i keep temps under control and the tune well away from detonation.
Posted on: 2010/2/19 13:12
VIC DYNO HIRE
From Perth WA AUS
Stock head gasket is like a fuse, it blows out before your motor does and will blow out pretty quick with 15psi. With a stock motor and stronger head gasket it will hold together a bit longer but probably cause more expensive damage to the rest of the motor.
Posted on: 2010/2/19 13:16
Datsun 1200 2Dr sedan.
From Perth WA AUS
Damn you beat me to it!! :)
Posted on: 2010/2/19 13:18
Interesting approach none the less.
Will be a very interesting project
Posted on: 2010/2/20 5:32
