CA has oil in the water !!
From mandurah
hey everyone what can i do to get all the water out of the sump and cylinders to stop them from siezing or giong rusty
please help me i dont want to FUK a brand new motor !!
Posted on: 2010/2/27 13:41
Re: CA has oil in the water !!
From hastings,vic
get motor hot if u can
drain oil, remove plugs
fill bores with crc ,ect
pull apart ASAP
Posted on: 2010/2/27 13:56
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
WTF is water doing in the cylinders in the first place?
Posted on: 2010/2/27 15:56
I hope you didn't tAke that whole running your car on water seriously?? Lol
Posted on: 2010/2/27 16:02
If u hadnt told us it was new id be inclined to lean in a warped head/blown head gasket area... Either way, water in your oil is troubling to say the least...
Posted on: 2010/2/27 20:17
From mandurah
haha bailz no i didnt try to run it on water
cos the motor is on a stand i was trying to sort a few bugs out (afm ,idle speed ) and i then it suddenly started running realy rough and i thought it was lacking fuel as i didnt put much in the tank ,then i decided it was time to put it away and when i dumped the water out of it there was little blobs of new oil
could this have something to do with the turbo burning oil ,or the oil filter block thingo not having some Oring thingy that darren told me about
im confused how can my new motor have water in the oil !!!!!!
Posted on: 2010/2/28 3:43
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
In what ways do u mean your motor is new? Has it been rebuilt? Or have u bought the engine second hand?
If your filter didnt have an O ring arond it, you would have a giant puddle of oil. As with your turbo, the engine would be blowing smoke to.
In the case of IF it was rebuilt, then it could be possible that whoever cleaned the engine pieces may have done so with water and when it was put back together it still had water collected? I have seen it happen a few times before... Just a thought
Posted on: 2010/2/28 4:16
From Melbourne, Oz
sounds like a blown head gasket. was the head retorqued after being ran up to temp then let to cool?
Posted on: 2010/2/28 4:38
"I hav achieved wood"
From mandurah
well i bought the motor of an engine builder in WA and he know what hes doin so it cant be his error and when i started it with water in it i didnt have it full but when i pulled the radiator hose of ,with the engine running i saw a lil bit of oil ,but there doesnt seem to be any oil in the block so i dont know whats goin on !
and yes the motor was rebuilt
and no i dint retorque the head after starting it the first time ,why will the motor settle in and stretch the head bolt after the first run
oh and the turbo was blowing smoke when i reved it up a little bit
Posted on: 2010/2/28 5:17
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Melbourne, Oz
Yeah once everything expands and settels ya realy ought to retorque th head. then again when its run in.
Posted on: 2010/2/28 5:25
