(1) 2 3 4 ... 96 »
Super Bee KA24DR Sedan
From Snohomish, WA USA
Note: Modification History - A12-A14-A15-Z24. Finished working on fitting KA24DE with Twin Weber 38/38 and Eaton Supercharger. No Fuel Injection so no 'E' and Supercharged so 'R'.....hence - KA24DR
Build starts on Page #16, Post #159.
New KA build on Page #90, post #896.
Enjoy!
Yes, the car use to be Blue.
Finally got around to fitting the Z24 motor into my sedan. I cut the firewall and tranny tunnel to get it in. I probably didn't have to go to the extreme with the sawzall but it made things easier. The motor is sitting up on blocks at the moment. I have the right position, I just need to build some engine mounts. Any ideas on what I should use for rubber isolators?
Next, a tranny mount.
Engine is rebuilt so as soon as I am done with the mounts, the motor will come out for a fresh coat of paint as soon as I reverse the sump on the oil pan. More cutting and welding. The engine bay will get a new coat of paint as well.
Battery to the trunk to make room for the draw-through root style Eaton supercharger fed by a Holley 600 4 barrel.
The broken H165 rearend will be replaced by a H190 (spider gears welded of course)
Lots of work to do!
Oh ya, 1/10/2010 marks my 10 Anniversary for joining the Datsun 1200 website! 37th member to join.
Posted on: 2010/1/7 3:13
Edited by datsa73 on 2010/1/7 3:31:21
Edited by datsa73 on 2012/10/27 22:35:59
Edited by datsa73 on 2013/2/4 19:32:31
Edited by datsa73 on 2013/2/16 5:39:43
Edited by datsa73 on 2014/3/20 17:19:35
Edited by datsa73 on 2014/3/20 17:27:24
Edited by datsa73 on 2014/3/20 17:29:07
Edited by datsa73 on 2017/2/1 18:46:36
Edited by datsa73 on 2020/3/14 16:10:21
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Eaton M62 SC 10 lbs. Boost / 150hp Progressive Nitrous
Ford 8.8 Posi/4.11
Re: Super Bee Z24 Mod
Looking good!
If it wasn't already a Super Bee-210, we could call it the Super Chicken Hawk.
(standard Chicken Hawk photo)
Yes, use Nissan 720 pickup Z24 isolators and engine brackets.
Posted on: 2010/1/7 3:51
As you can see by the supercharger crank pulley, I had to move the motor back to make room for the crank pulley and the radiator. If it wasn't for that, I would have not have had to cut the firewall.
Pull-a-Part has a pickup so I may look for the motor mounts. Thanks!
Posted on: 2010/1/7 4:22
'73 2 Door Sedan
Ford 8.8 Posi/4.11
From Perth WA
that should frikin fly!
Posted on: 2010/1/7 5:24
datsun 1000, Its not the size its how u use it.
From Christchurch NZ
You're an animal Ernie! I'm loving it!
BTW, I never knew you'd been a member for so long! I've only been using the net for a few years. this was the first site I joined too. (been here for almost 7 years)
Drag racing is a disease that can only be cured by poverty. You wanna crank the quarter instead of the 1/8 with your new motor so I can compare apples with apples with my performance.
Posted on: 2010/1/7 8:37
Forced Induction!
Just finished the tranny mount and the engine mounts are complete as well. Will post some photos soon.
Now that that's done, I can close up the tunnel and repair the firewall. The shifter sits about 6 inches back so I need to move the E-Brake. Next is to remove the battery mount and start fitting the Supercharger in. After I get that in place I can start fabbing the Holley Carb intake.
This is so fun, its almost to easy.
Posted on: 2010/1/20 4:11
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Is the shifter still in a comfortable/efficient place?
Posted on: 2010/1/20 4:15
The shifter will be shorter and if I have to, I can reverse the shaft and bend it accordingly. It will work.
Posted on: 2010/1/20 4:20
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Update:
Pushed the car out for a wash after being in the garage for over 6 months.
Engine rebuilt to stock and painted with supercharger mounted.
Nicely and tightly fitted in engine bay. Alternator bracket built and moved to left
side of engine.
The oil pan was a pain in the butt to fab but is completed. Next I will be working on replacing the H165 rearend for a H190. All Fun!
Posted on: 2010/3/12 7:32
'73 2 Door Sedan
Ford 8.8 Posi/4.11
From Adelaide, Australia
Very tidy mate, just scored a Z18 turbs setup Im gonna have a play with at a later date on my Z24, looks like yours is going to be a beast once finished!
Any chance you can post some pics of the sump?
Posted on: 2010/3/12 7:48
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
(1) 2 3 4 ... 96 »
