« 1 2 (3) 4 5 »
Re: Modern windscreen wiping motor
for sure, will pull it tomorrow after work and post the pic :)
Posted on: 2010/4/19 11:50
Luck is what happens when Preparation meets Opportunity.....
From Townsville, Qld
One comfort I'd like would be an intermittent setting like the new ones, it's annoying turning the switch on and off every 10 seconds in the light stuff
Posted on: 2010/4/19 12:00
From Brisbane
Hmmm i may experiment all this soon too. I hate storm season! wipers are to slow to see anything so always got to pull over and wait.
Posted on: 2010/4/19 12:10
i can buy a kit from jcar to have intermittent setting
Posted on: 2010/4/19 12:28
Car free
Lowmion where abouts are you? I really like your setup very clean and industrial looking.
I dont want to put you out but if you are willing to take a fiver on top of the price of
the T section, You could get a group buy happening. Its the best setup Ive seen in years.
Posted on: 2010/4/19 12:31
d i have one fs
Posted on: 2010/4/19 12:48
Car free
u can buy copper t's like 2x 1.5inch and 1x .5inch from pluming suplies
Posted on: 2010/4/19 13:04
Car free
Ive been to plumbing supplies in the past for such a fitting and also
for the one in the back of the heads for the heater but never found
the right size T one. Will have to go looking to other plumbing places
but its such a hassle going to so many of them and turning up silch.
the only other option is SS but not as good as lowmion setup I reckon
as its straight tube reduce T 31mm inside diameter and 12 reducer
http://www.geordi.com.au/Products15d.htm
jpg  Teereducer.jpg (3.43 KB)
737_4bcd01aed5ed5.jpg 234X200 px
Posted on: 2010/4/20 1:47
Edited by D on 2010/4/20 2:19:41
Edited by D on 2010/4/20 2:21:58
just took mine out and the outer diameter of the T pipe is 27mm inside 22mm
reducer pipe is 15mm outside and inside 13mm.
Called His, benton plumbtec and a few others and only have 25mm x 19mm so far
so really looking forward to seeing what Lowmion has used to solve the most
frustrating thing I find with the heating system on old A series engines.
Posted on: 2010/4/20 4:29
Online
This is what you could use for a Datsun 1000:
Or for advanced technology maybe something like this:
D is this what you are describing?
or this?
jpg  water connector.jpg (6.59 KB)
174_4bcd2a0ee94ff.jpg 200X150 px
Posted on: 2010/4/20 5:16
« 1 2 (3) 4 5 »
