(1) 2 3 »
which cam? tell me your experiences....
From Melbourne Vic
I've tried to do research but not getting a lot of info and different manufacturer's specs sheets are confusing me!
Unless there is a reason why i'm going to get a wade cam as they are close to me and give me trade price so here's the story
A15 engine, possible overbore and aiming for 10:1 comp
head ported to gx specs with 41mm inlet and 33mm exhaust valves double valve springs shimmed to take plenty of lift
quad 40mm (from memory) throttle body fuel injection on long runners
long as i could make fit 4-2-1 extractors into a 2 inch system
in a 700ish kg 1000 wagon.
currently has a wade 169 which is known as a 70 30 cam. the cam falls on its face after 5ish but produces great torque and drivability.
It is for a street car so i don't want a silly powerband just a better cam for the application without going too big
what have people used and how did it perform?
cheers
Posted on: 2010/4/20 8:49
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: which cam? tell me your experiences....
Hi Mate,
Got a Wade 140 grind, which is 75-41 in my 1200 coupe A15 twin Dellortos.
Good mid range torque considering, very happy with that and a good top end. I have 32mm chokes though, really need some 34mm to take advantage of the big top end of the cam.
Go for it and report back on the awesome power you make with the TB injection setup!
Cheers
Matt
Posted on: 2010/4/20 9:01
From Southern Highlands, NSW, Australia
Wade 140 is the sh!t, My A15 runs 45mm throttle bodies and goes pretty good with that cam. Plenty of midrange and top end.
Posted on: 2010/4/20 9:25
'72 1200 sedan hillclimb/supersprint car
From Melbourne Vic
definately sounds the goods! i went in to wade today and they were vaguely recommending a cam that is much smaller than that.
how would you think it would go as a street cam? pig down low?
Posted on: 2010/4/20 13:26
From Brisbane
Just for a giggle,
I run a Wade 629B, 86/56 with .497 valve lift, Not really a street grind.
Seriously though, from experiance go for a bigger camshaft over a smaller one , not to massive, the A-series love to breath.
Posted on: 2010/4/20 14:16
I wonder what that member from South Africa is running?
He posted recently on his rebuild.
Posted on: 2010/4/20 14:46
From Perth WA AUS
Go big! you'll love it. Might be a pig in traffic but if your like me you will love that too!
Posted on: 2010/4/20 14:49
Datsun 1200 2Dr sedan.
From mandurah
you like it big dont you levey hehe ,i want a bigger cam cos i have to have the choke on to make it sound lumpy haha , my cam sounds ok
Posted on: 2010/4/20 14:56
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Melbourne Vic
it sounds like the 140 could be the go, the other option is their one a step down from that. anyone have one in a street car?
Posted on: 2010/4/20 22:48
From Melbourne, Australia
from those responses i would go one step down
why not make it a nice street car, nothing sillier than a high reving machine on the street
if you like traffic light derbies, its sounds rediculous if the guy next to you is revving the absolute ring hole out of his machine, even if he is a bit quicker
i love the a15 with a mild cam, burn away from the regular traffic at 3/4 throttle with out going past 4000rpm and not even sounding like your trying
surely the motor will last longer if your not reving to 7000 plus, just booting along using the torque not often going above 4-4500rpm
with the injection you will get much better performance down low too
i think you will find all the high reving junkies are running webers/delortos, the high revs seem great with these carbies cause they only ever run well at full throttle
Posted on: 2010/4/21 0:04
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
(1) 2 3 »
